mseven | more changes for 2011...and stud question | ||
Started set-up on the new Billet Specialties f body rims. The fit is awesome with no mods required to the calipers. Actual clearacne is about 1/4" all the way around (pic. makes it look a tad tight)
To those who have replcaed studs, does anyone know the original knurl dia. of the late model c4 (either in mm or inches). and or the actual hole dia. of the flange/hub? here's a couple of shots..note the shims on the hawk pads failing again..... [IMG]http://i55.tinypic.com/209ppqt.jpg[/IMG] [IMG]http://i55.tinypic.com/34r6u0w.jpg[/IMG] [IMG]http://i53.tinypic.com/f9qfjq.jpg[/IMG] [IMG]http://i53.tinypic.com/ehkm14.jpg[/IMG] [IMG]http://i56.tinypic.com/6f6nm9.jpg[/IMG] |
Posted on: 2011/2/10 14:06
bogus | Re: more changes for 2011...and stud question | ||
those will look SWEET!
The best I could find was this measurement - 12x1.5x14 in the parts fiche... |
Posted on: 2011/2/10 17:08
rklessdriver | Re: more changes for 2011...and stud question | ||
Those look really good. REALLY GOOD!!
Sizes?? Your car has the early narrow suspension right? Will |
Posted on: 2011/2/10 20:06
mseven | Re: more changes for 2011...and stud question | ||
Thanks guys
sizes are 15x4-2.25 b.s., and 15x10-7.5 b.s. Mine is a 90 (later offset) so they were the 56 mm b.s. on the a molds. I'll be knocking out the studs tonight. It appears that there are a couple of numbers for the knurl dia. I'll know more when I actually measure the flange hole and the original studs...hopefully. |
Posted on: 2011/2/10 20:51
Matatk | Re: more changes for 2011...and stud question | ||
Wheels look nice, Mick.
I looked briefly, but all I could find were part numbers, no real dimensions other than the stock length is supposed to be 1 5/8" and there are a bunch of aftermarket studs - arp,drm, etc. ARP lists them as 12mm x 1.5 pitch. GM #9591291 Matthew |
Posted on: 2011/2/10 23:15
Thanks Matthew,
The issue seems to be the knurl diameter. According to most GM numbers it "should be" a .509. After removing stock studs what I'm seeing on a used stud is approx. .497-.505. I'm guessing with compression of the knurl it will lose .005-.007 dia. The original hole size with spline is difficult to determine it "looks like".492-.497 but definetly not .500 ? (length is easy am going to use 2 1/4") |
Posted on: 2011/2/11 14:57
Josh | Re: more changes for 2011...and stud question | ||
Wheels look great man! I don't have any answers as far as stud dimensions, but the wheels look awesome. Can't wait to seem them powder coated.
Posted on: 2011/2/16 4:17
-=Jeff=- | Re: more changes for 2011...and stud question | ||
here is an OEM replacement
http://www.dormanproducts.com/p-2568-610-323.aspx same length as stock but is threaded to the end. I am using these with a 1/4" spacer on my Shelby wheels Knurl Dia. is 12.80mm or 0.503937" |
Posted on: 2011/2/16 14:50
vetteoz | Re: more changes for 2011...and stud question | ||
Replaced my fronts a couple of weeks ago ; these were perfect fit http://www.summitracing.com/parts/ARP-100-7708/ |
Posted on: 2011/2/17 13:27
