131 user(s) are online (50 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
Raidmagic T56 into an early C-4 swap questions
Florida
168 Posts
Hey guys. I just made a deal on a wrecked 2000 WS6 Trans Am today. My main target for the purchase was the transmission and it's parts. My question is can I use the clutch master, slave and all from the Trans Am? I have pedals already from an 86 4+3 car so I'm hoping I can use all the parts from the donor car. Also what to do about the C-beam. I know someone makes an adaptor but in talking to -=Jeff=- he said it wasn't a real good piece. Anyone with experience? Jeffvette I guess bought one and redid it better.
Any advise you can offer would be great. I can't wait to get this 6 speed behind my LS1
Posted on: 2011/2/17 22:36
bogus Re: T56 into an early C-4 swap questions
http://www.prostreetcustoms.net/index.html
Those guys have a T56 conversion for the c-beam.
At this stage, you use all LS1 parts for the clutch... There is just no reason to so anything else. What I don't know is if you will need to mod the floor pan, but I doubt it. You may need to move or enlarge the shifter hole.
Posted on: 2011/2/17 23:03
Raidmagic Re: T56 into an early C-4 swap questions
Florida
168 Posts
Looks good, thanks for the link. It's a good price too. I'm sure I'll have more questions when I get it all apart
Posted on: 2011/2/18 0:37
CentralCoaster Re: T56 into an early C-4 swap questions
You're definitely going to have to cut up the center console for it.
Stay away from offset shifters, they are junk.
Also, don't the fbody masters have an angled bolt flange? Maybe there's a C5 unit or universal unit that fits with less work. Or if the C4 master is the same bore, try that.
Posted on: 2011/2/18 1:27
Josh Re: T56 into an early C-4 swap questions
The F-body masters do have an angled bolt flange, so they aren't a direct bolt in for a C4. I don't know about a C5 master, it may work out of the box.
Posted on: 2011/2/18 7:15
It looks like the C5 clutch master is straight...
http://info.rockauto.com/getimage/get ... nfo_resize/DUS/385502.jpg
You may need to modify the shaft length, tho...
Also, check racing supply for like a generic Wilwood or something of that nature.
Posted on: 2011/2/18 19:24
Florida
168 Posts
Will I have a clearance issue with the slave and my headers? Why does it matter the master is angled, will it hit the firewall?
Posted on: 2011/2/19 0:33
vetteoz Re: T56 into an early C-4 swap questions
Raidmagic wrote:an adaptor but in talking to -=Jeff=- he said it wasn't a real good piece. Anyone with experience? Jeffvette I guess bought one and redid it better.
Somebody from CF home made version
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/Trans/GearboxT563.jpg[/IMG]
Posted on: 2011/2/19 0:44
What I like about the store bought conversion is the additional cross brace. Not that it can't be added here...
Posted on: 2011/2/19 1:06
-=Jeff=- Re: T56 into an early C-4 swap questions
Bartlett, IL
573 Posts
The one Bogus posted looks different then the one I saw a few years back
Posted on: 2011/2/19 2:45
-=Jeff=-
1990 Corvette ZR-1 #1051
Florida
168 Posts
I like that one Bogus posted. I'd rather cough up a few bucks than spend the time working out all the dimensions of one myself.
Anyone with an idea on the slave and header clearance?
Posted on: 2011/2/19 21:53
no idea on the clearance... It makes me wonder... I know the LSx motors are more compact and do sit farther back in the engine compartment. But the master cylinder sits to the left of the brake master, and only marginally lower. I would be shocked if the headers were that far out.
I went looking for a right angle mount for the master...
I know they are made; I have seen them in the past, but for the life of me, I can't find one on the web!!! And I wonder if it would really help.
Posted on: 2011/2/20 20:17
Florida
168 Posts
The master isn't my header clearance concern it's the slave. I read somewhere else someone was selling a T-5 and modded headers for the slave.
Posted on: 2011/2/20 22:28
hm... the slave, I thought, was tucked inside the bell houseing?
Why not get a hydraulic throwout bearing?
Posted on: 2011/2/21 1:23
Florida
168 Posts
I guess at this point instead of guessing I'll just wait untill I get it out and in my hands and see exactly what I'll be working with. I just don't know enough about them to guess on how they are put together.
Posted on: 2011/2/21 2:12
Hydraulic throwouts have a lot of advantages... not withstanding, less parts.
Posted on: 2011/2/21 5:45
Florida
168 Posts
Can you explain the Hydraulic throw out bearing? I'm not real versed in anything standard shift. Is there different needs to run one other than the normal clutch master?
Posted on: 2011/2/21 20:56
BillH Re: T56 into an early C-4 swap questions
Stock style C4 T/O bearings are actuated bo a clutch fork, it's in contact with the throwout bearing that presses on the clutch plate. The fork sits on a pivot and goes thru a hole in the bellhousing where attaches to the slave cyl. The slave pushes the fork which pushes on the T/O beraing.
A hydraulic T/O bearing is a one piece assembly that uses the hydraulic pressure to push directly on the T/O bearing eliminating the slave and clutch fork.
Similar to this:
jpg  41A69ERVAGL__SS500_.jpg (0.00 KB)
Posted on: 2011/2/21 21:24
Florida
168 Posts
Ahh that makes perfect sense. Thanks. I can see how that would be better.
Posted on: 2011/2/22 0:43
