200 user(s) are online (141 user(s) are browsing Forums)
postalvette 86 fan problems
23 Posts
Ok working on an 86 that has the same fan problem as my sons 84 but I know that the 86 has a different wiring schematic. Anyone out there have the fan wiring schematic for an 86. Thanks for all the help
Posted on: 2011/3/10 21:33
CentralCoaster Re: 86 fan problems
This isn't the wiring diagram, but still shows the circuits and diagnostic info for 1986.
pdf Cooling Fan Control.pdf Size: 434.14 KB; Hits: 253
Posted on: 2011/3/10 23:21
Matatk Re: 86 fan problems
What Kevin posted is better than a wiring diagram. Let us know if you need any help!
Posted on: 2011/3/11 2:34
postalvette Re: 86 fan problems
23 Posts
Thanks for the diagram. Someone had tried to fix this before by running a wire from the hot lead on the air compressor directly to the fan. I see that both inputs go through the ecm. Found that the a/c system needs charged, would this cause the ecm to not send a signal to turn on the fan? Replaced the fan relay and checked wiring on connectors but still not getting voltage to the fan. Will recharge the a/c system and see what happens. This seems to be a common problem on the c4 line, either runs all the time or not at all, will keep you posted as to what I find.
Posted on: 2011/3/11 12:37
BillH Re: 86 fan problems
Shouldn't. Looks like the signal to the ECM is either/or (either the a.c or the cooling switch).
Note on the chart that they say to disconnect the temp sender and that should "default" the ECM which should turn the fan on.
You can also use a jumper on the relay ground wire. Groulding that wire should turn on the fan and will tell you if the relay and wiring to the fan is correct.
Posted on: 2011/3/11 13:25
23 Posts
Finally found that the fused link from the battery to the relay connector kept blowing when the fan comes on. It had a 15 amp fuse in it, replaced it with a 20 amp and it still blew. Anyone know what the correct amperage is? Put a piece of wire in to jumper and the system works as it should but should the fan draw that many amps?
Posted on: 2011/3/13 5:18
vetteoz Re: 86 fan problems
Schematic for early cars only shows the fusible link ( No rating given ) ;
On later cars ,Pri fan fuse is 30A
Posted on: 2011/3/13 7:44
23 Posts
Thanks for the info, put a 30A fuse in and works as advertised. I'm suprised at the difference between the fusebox fan fuse (3A) and the fusible link
Posted on: 2011/3/14 5:20
postalvette wrote: I'm suprised at the difference between the fusebox fan fuse (3A) and the fusible link
3A is only the control circuit for relay ; not the power going through relay to fan
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/Fan86-89.jpg[/IMG]
Posted on: 2011/3/14 6:10
