117 user(s) are online (61 user(s) are browsing Forums)
corvetteronw Bonehead Corvette moves
Lowell, MI
A post on another forum got me thinking about the time I cut a hole in my C3's hood to clear the aftermarket intake and carb that was "guaranteed to fit under the hood of your 81 Corvette".
I remembered what my Grandpa taught me, "Measure twice and cut once". Hell, I got a chalk line out and found the correct space from the cowl and the exact center of that hood. I measured THREE damn times. I am not going to F this one up!
My plan was to glass in a fiberglas cowl scoop so I wouldn't look like a dip whiz while driving around with the carb sticking out of the hood.
Cut the hole perfectly round and even made the hole an inch or so larger than needed in case the engine torqued to the side of my newly hot rodded 355! YEAH - I'm bad! I am an ACE mechanic and body man!!!
Bolt the hood on, lower it and--------------holy schnizzle, I never imagined that GM placed the engine slightly to the right of center in the chassis!!
Bondo to the rescue as I glass in a piece and recut the hole slightly off center.
I got the scoop glassed in and she looked good but I will never forget that screw up.
OK, confession is good for the soul. Let's hear your shameful moment(s).
Posted on: 2011/3/11 6:39
383tpimachine Re: Bonehead Corvette moves
Corpus Christi
976 Posts
Head swap no start?
About two weeks before I started on my head and rr swap I installed a fuel cut switch that is "easily knocked".
Drove vette into garage. Started the teardown. Install went smooth. Everything perfect. Went to fire it up. Ran for 5 or so seconds then died. Would crank with not a single issue just no start.
Me and my dad checked everything but fuel since we didnt have a gauge at the time. Could not figure it out.
Next morning went out, flipped the switch, fired right up.
Worst feeling going from running fine to not and then feeling like a total idiot the next morning.
Posted on: 2011/3/11 7:04
1970 El Camino-Awaiting LSX
bogus Re: Bonehead Corvette moves
A few years back, the AFPR failed, dumping fuel into #4 and 6 cylinders.
I needed to blow them out, so I removed the plugs, and then proceeded to start the engine... oopsie... forgot to kill the coils!!! FIRE!!!! Not bad, but potentially scary.
Posted on: 2011/3/11 8:00
BillH Re: Bonehead Corvette moves
I sold my 63, I sold my 2- 65's , I sold my 66, I sold my 76.
My little bonehead mistakes in the shop don't compare to that stupidity.
Posted on: 2011/3/11 13:16
Ultraman Re: Bonehead Corvette moves
14780 Posts
I am with Bill on that. Sold my 63 vert thought I had to but probably could have worked something out. Now I doubt if I will ever have another. Also the 55 Bel air 2 door hardtop.....what's the matter with me!!
Posted on: 2011/3/11 16:26
corvetteronw Re: Bonehead Corvette moves
Lowell, MI
Great Ultraman. Thanks for reminding me. Two door 57 Chevy post. Bought it minus engine and left front fender from a wrecking yard for something like $150. Put a 421 tri-power Pontiac hi-po engine in it from a wreck and bought another fender at a u-pick yard for $10. Found out the engine had a bad knock and I needed money to fix the 4-speed in my 63 Cheby that I used to go to work and on dates.
Sold the entire rig for about what I had into it.
Think what that would be worth today if I had stored it somewhere?
I think this happened around 1966. Dumbassed kid!
Posted on: 2011/3/11 21:29
TommyT-Bone Re: Bonehead Corvette moves
33800 Posts
For the life of me I cannot think of any bonehead moves. Lucky me.
Posted on: 2011/3/11 22:21
Lowell, MI
Think harder. I bet everyone has had their significant other come into the room with the Visa bill in hand saying, "What the hell is this charge for $443.29 at (pick one of the Corvette suppliers)?!!!!!!!!!!Resized Image
Posted on: 2011/3/11 23:32
33800 Posts
I pay the bills.
Posted on: 2011/3/11 23:39
