216 user(s) are online (158 user(s) are browsing Forums)
autoxtraz C4 4+3 Tranny - how remove reverse/key lock cable
5 Posts
Hi all - got 1 1986/7 C4 with 4+3 Super T10 box - want to know hot to remove the cable that runns from tranny that has to be in reverse before ignition key can be removed - is there also a switch somewhere attached to the clutch or ? Seems like a pointless performance having to put into reverse all the time. All help appreciated. Jock
Posted on: 2011/4/14 20:39
bogus Re: C4 4+3 Tranny - how remove reverse/key lock cable
20860 Posts
Jock,
Welcome aboard!
Curious, you have a UK email, how did you find us? What part of the UK are you from?
To answer your question, that cable runs from the shifter to the steering column. The easy solution is to remove the console cover and the cable is right there on the linkage, IIRC. Remove accordingly and test.
The problem should go away.
Posted on: 2011/4/14 22:17
autoxtraz Re: C4 4+3 Tranny - how remove reverse/key lock cable
5 Posts
Thanks for the reply - so removal requires no mods? What happens when clutch is depressed (no I dont mean see a shrink!) is there an over ride switch linked to clutch pedal that activates when in reverse and depressed?
Jock
Posted on: 2011/4/15 15:55
20860 Posts
The cable, once disconnected, should disable it all. It's been a while since I was in one of those mechanisms, tho.
I would suggest you get a copy of the Helm Factory Service Manual. They are available on eBay these days. I don't think Helm prints them anymore.
Posted on: 2011/4/15 17:05
vetteoz Re: C4 4+3 Tranny - how remove reverse/key lock cable
Switch on clutch pedal is seperate item requiring clutch to be down before engine can be cranked over
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/Starter-1.jpg[/IMG]
Posted on: 2011/4/15 23:39
CentralCoaster Re: C4 4+3 Tranny - how remove reverse/key lock cable
I think you're getting some of the "safety" features mixed up...
There's a clutch safety switch... must have pedal down to turn ignition.
There's a reverse lockout... must lift to engage reverse.
There's an ignition lockout... must have car turned on in order to move shifter out of reverse.
Posted on: 2011/4/16 0:17
5 Posts
Thanks guys - located in sunny Scotland - been with Yanks for years, currently got 99 Dodge Dakot R/T fully tuned and 1987 Vette Callaway TT - just trying to get it sorted - finished manual rod linkage mods today - world of difference, next new sump - must have been bumped of a spped bump when it was in London, then overhaul of power steering pump - which is p*ssing fluid all over the engine bay and down onto tranny etc. Finally new windlace/weatherseal kit and new carpets/panels etc. On the road just now but tranny was totally crap could harley get a gear - still managed a 176mph in it though.....not bad for an old beast like this.
Wanted to remove clutch start switch and mechanism that locks the key in barrel until tranny in reverse - seem totally pointless safety items.
Posted on: 2011/4/16 14:11
rayquayle Re: C4 4+3 Tranny - how remove reverse/key lock cable
139 Posts
Is this the silver gray Callaway that Keith Beschi has had up for sale for years?
Posted on: 2011/4/16 18:50
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
5 Posts
Don't know how to take that question - Is that meant to be some sort of smart arse comment or a genuine ask?
Answer is simply NO! Belonged to a guy from London who owned it for 10 years until passed away.
The matching sister car you may be refering to may be the one advertised on EuroVette's site - this was was featured in the C4 Originallty Guide book under the plate 13 LUR - also owned orignally by Eurovette.
Posted on: 2011/4/18 15:14
captmike13 Re: C4 4+3 Tranny - how remove reverse/key lock cable
Hillsboro Mo
2166 Posts
If need a manual here's Helms where to get one.
Welcome aboard.
Posted on: 2011/4/18 15:46
13 GMC 3500 dually
captmike13@yahoo.com
139 Posts
Uh, OK then. Not sure what you meant by smart arse comment. I've known Keith for many years and just wondered if this is the one he'd had for sale.
Posted on: 2011/4/18 21:39
NCM Founder #2896
NCM Lifetime #672
5 Posts
Just the way it was written - "up for sale for years?" sounds like a back handed comment. Anyway, Keith was the initial owner of this one, eventually ended up at Claremont then Romford. Just trying to restore the usual nasty interior/weatherseals/front airdam as the outside and mechanicals are all ok 'cept for the leaking p/s pump - £43 for a seal kit!! Impressive fuel consumption for motorway runs at 65/70mph - 23.4-26.7 mpg.
Posted on: 2011/4/19 8:10
139 Posts
Please forgive me. Although I've lived in England for over 20 years, I'm still an American and haven't gotten all the lingo down. I'm not sure what "back handed comment" means, but Keith did have the car for sale for a long time. Nothing untoward implied. Could have been he was asking too much, could have been the people in the UK didn't appreciate the true value of the Callaway. I wasn't sure if Keith had sold other Callaway's or not, so was trying to make the distinction if he had. I'm just glad you didn't take exception to my "silver gray" comment! Best of luck with it, I've always been a huge fan of Callaway cars, but could never afford one.
Posted on: 2011/4/19 9:27
NCM Founder #2896
NCM Lifetime #672
