324 user(s) are online (178 user(s) are browsing Forums)
The ...
joeld Fuel Pressure drops quickly
On my 89, stock FPR and possibly OE pump.
Pressure comes up instantly with key on to 41 lbs.
And then, with key still on, pressure drops down to 19 lbs within 3 or 4 seconds. It takes about 10 mins more to slowly drop to 0 lbs.
Car runs good, with the exception of long crank times. More when engine is cold.
IIRC, pressure should hold for a lot longer that this?
Posted on: 2011/5/16 0:40
BillH Re: Fuel Pressure drops quickly
Yea definately. Sounds like a bad pump or check valve.
Posted on: 2011/5/16 1:31
joeld Re: Fuel Pressure drops quickly
Yea, I'll just replace the pump soon. I knew my luck was about out since it's been almost a year since anything "broke".
Thanks for the reply
Posted on: 2011/5/16 2:37
Matatk Re: Fuel Pressure drops quickly
What Bill said. Other possibilities are the fuel injectors leaking or the FPR regulator leaking. There are FSM steps to narrow it down. Best way is to pinch the feed/return lines at the tank and see if pressure still bleeds down.
Photobucket
Photobucket
Photobucket
Photobucket
I also have a write up in the tech library for replacing the fuel pump.
Posted on: 2011/5/16 13:02
Thanks for the info Mat! I have the FSM, was just too lazy yesterday to go thru all the steps to check for this problem. My injectors and pressure regulator are approx 2 yrears old. I know the plugs are dry and and no liquid fuel from regulator.
And, since I'm thinking this car has the original pump it's no big deal to just replace it.
Seems like most people are happy with the Racetronix kit #fpa-011?
Posted on: 2011/5/16 15:25
Joel, note that there's also an install kit if you need it.
http://www.racetronix.biz/customkititems.asp?kc=FPA-011&eq=
Posted on: 2011/5/16 15:58
hdfire Re: Fuel Pressure drops quickly
Crest Hill, IL
48 Posts
Replaced my pump about 2 weeks ago with the racetronix parts. Much easier task than I anticipated. Still having some other issues, but the pump & install kit was top quality!
Posted on: 2011/5/16 17:10
Thanks Bill. That is the kit I would go with.
I thought Summit had these, but can't find it listed on the web site.
Posted on: 2011/5/16 17:17
Funny, I was in Summit today.
Nope, doesn't show up but they do have the AC Delco.
http://www.summitracing.com/parts/ACF-EP375/
Posted on: 2011/5/16 23:04
When I calculated price, the racetronix was cheaper for a walbro pump/setup than the ac delco with sock and gasket even with gm "employee" price.
Joel - get the kit:
Base Price: $ 109.00 Your Price: $ Quantity:
To take a printable version of this Kit Click here.
Item Name Price Qty
Fuel Pumps - In-Tank More Info
190/Hr Fuel Pump $ 1
Fuel Pump Installation Kits (RX-PIK) More Info
C469 1986-89 Fuel Pump Installation Kit $ 1
Select options; the kit price is automatically updated with the new price
Item Description
FPA-011 - 1986-1989 C4 Corvette Fuel Pump Assembly - Factory Upgrade 190LPH
* Walbro 190L/Hr Pump
* Filter sock - 30 micron filtering (factory=70 micron)
* High pressure fuel line
* Stainless gear clamps
* Rubber pump mount
* Pump sound insulation sleeve
* C4 fuel tank gasket
* Stainless hex-head tank bolts, washers and o-ring seals ( 9 pieces)
* Hex key
Posted on: 2011/5/17 1:18
One more question: I've seen a couple of posts with folks using a zip tie to secure the wires inside the tank. IIRC, Mat had this tip in his write-up. What kind of zip tie can withstand the gas? Most plastics I've dealt with in the past would dissolve in gas after a few hours.
I must be missing something here.
Thanks
Posted on: 2011/5/25 2:04
I just used what I had laying around. I don't know how well it will withstand the gasoline. I'd say get the outdoor rated ones vs regular, they are stronger and more resistant to elements.
Posted on: 2011/5/25 11:26
Thanks
I had the connector come loose and shut down the pump (on the car in my avatar, watched the rest of the race sitting in the grass). Definately was zip tied after that.
Don't worry about the plastic, half the fuel tanks out there are plastic.
Get decent zip ties at HomeD, they used to carry T&B (Thomas & Betts). Just don't get zip ties from harbor Freight, they are real crap.
Posted on: 2011/5/25 13:31
OK New pump is in, pressure holds better, but most of all the car now starts almost instantly! Always before there was a long crank time, been that way for 11 years. Feeling a little love for the car again.
Thanks
Posted on: 2011/5/25 23:56
larry00 Re: Fuel Pressure drops quickly
4 Posts
Most all the new pumps are good but look out for the material used for the hose !
Cheap crap turns to mush in gasoline and since much of our stuff comes from overseas it's hard to tell apart from the good stuff.
It won't show up for a while then you hear the pump but get little or no fuel pressure !
If you can't tell the difference go to NAPA and buy the good stuff. Cheap insurance !
Posted on: 2011/5/31 15:19
tomkatmn Re: Fuel Pressure drops quickly
USA
9 Posts
Hi, I just installed the FPA-011 pump and C44 wiring assembly in my 89 corvette, I was having long start ups/cranking time also, now it just turns over and wont fire up...any thoughts why it wont fire up now?
Posted on: 2016/9/22 6:36
Check the fuel pressure with a gauge, should be 42 psi with key on engine off.
Posted on: 2016/9/22 13:56
Yep, you have to start there, you need to know if there's pressure at the injector rail.
Posted on: 2016/9/22 14:44
bogus Re: Fuel Pressure drops quickly
Can you hear the pump fire up?
It should run for 2 seconds before the car starts to build pressure.
Posted on: 2016/9/22 17:44
USA
9 Posts
no pressure at the rails, not even coming out of the tank , i can hear the pump but no fuel
Posted on: 2016/9/22 18:38
USA
9 Posts
the pump seems to run for the 2 sec. but no fuel at the tank , pulled the line off at the tank turn key on pump made a sound , but no fuel.
Posted on: 2016/9/22 18:40
If you're sure pump is running, I'd say pull the pump back out. Possibly the pulsator slipped off or even the pump is loose from feed line.
Posted on: 2016/9/22 20:25
USA
9 Posts
the pulsator is remove for this pump , and I check feed line , racetronix told me to check polarity so that's what im going to do now.....let you know if that works..
Posted on: 2016/9/22 20:33
USA
9 Posts
Fyi polarity was wrong, car starts now.....still have the fuel pressure dropping fast...key on 45psi....20sec..drops to 15psi....2min. down to 0.....check pressure regulator its good...fuel injectors seem ok not getting a rich starting issue .....just the long crank time....what else im I missing?
Posted on: 2016/9/22 21:48
Glad it was a easy fix! I just assumed that kit was a plug-n-play.
The 1989 model year has a slight quirk in the "tune" that requires a longer crank time. Some info here:
http://www.corvetteforum.guru/modules ... id=192657#forumpost192657
Posted on: 2016/9/22 23:27
My fuel pressure drops when off. I don't even worry about it. As for the long crank times, see the thread above. It's in the factory parameters for the 89.
Posted on: 2016/9/23 4:03
USA
9 Posts
I assume it was plug and play also , sometimes its true about assuming LOL
thanks for your help and info.
Posted on: 2016/9/23 12:43
USA
9 Posts
Where can I get a chip?
Posted on: 2016/9/23 12:51
Do you have any modifications to your car or is it stock? There are mail order companies, I currently use PCM of NC.
http://www.pcmofnc.com/product/1986-1 ... ette-mail-order-tuning-3/
Figure at least $160. You don't get any real power/performance gains from a chip. Most guys with a stock setup who want a chip do it to lower fan temps, eliminate VATS, etc. If you have modifications, that's where it's more important.
Posted on: 2016/9/23 13:59
USA
9 Posts
im the 2nd owner the car only has 30k on it, I've done small mods to it , better air filter flow, other than that just stock.....if the chip helps with a lower crank time and or other improvements is all I need at this time. any advice I would appreciate. thanks
Posted on: 2016/9/23 18:06
