245 user(s) are online (144 user(s) are browsing Forums)
Also known as NHMS....
« 1 (2)
Matatk Re: Dreaming of a new engine
22806 Posts
JeffK wrote:
I do need to find out where to rent an engine hoist still.
Buy one at harbor freight with a coupon from the sunday paper then sell it. Or look on CL for a used one.
Posted on: 2011/5/23 2:11
JeffK Re: Dreaming of a new engine
High Point, NC
1440 Posts
Found one! The guy that is buying my old block has a hoist and a stand that he will lend me.
BTW - I went with the 1010 head gaskets, standard vol oil pump and the double roller timing set.
up charge for the head gaskets $50
Up charge for the dbl roller $20
Posted on: 2011/5/23 13:59
flyboy Re: Dreaming of a new engine
Your builder probably knows this, but I would want to make sure the set will fit under the stock cover (the one from Summit in r-d's post says it won't) as there is no clearance behind the water pump for a deeper cover, on mine anyway. My dbl. roller from Jeg's (I think it's a rebranded Cloyes, p.n. 555-20145) fit under the stock cover but needed a little clearance grinding on the block.
Posted on: 2011/5/23 18:10
High Point, NC
1440 Posts
He already mentioned that he would have to clearance the block alittle. That makes me feel more confident in his knowledge.
Posted on: 2011/5/23 18:23
High Point, NC
1440 Posts
Finally got to meet the guy last night. He is a very knowledgable guy, I spent 2 hours up there talking to him. I learned a couple of things about the internals of an engine. Unfortunetly my block was still at the machine shop. He showed me the pile of parts that was waiting for my block to get back and we added the pile of parts that I had in the trunk of the VW.
He has a sweet 86 that he built a 383 for and painted Atomic Orange. It was beautiful and sounded bad-ass.
I couldn't hardly sleep last night.
Posted on: 2011/5/24 11:56
High Point, NC
1440 Posts
WOOHOO! Going to pick up the engine tonight!
Posted on: 2011/5/27 11:31
22806 Posts
Well?
Posted on: 2011/5/28 1:28
High Point, NC
1440 Posts
Got the engone home. Will post pics later.
Getting my ass kicked by 2 of the bellhousing bolts on the drivers side.
Calling it a night before I do somethimg crazy like pull the trans.
Posted on: 2011/5/28 4:25
High Point, NC
1440 Posts
It's in!!!
Old engine getting ready to come out
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306709616.jpg[/IMG]
Old grimy engine out
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306617804.jpg[/IMG]
The hole
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306709858.jpg[/IMG]
New engine in the hole
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306617803.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306617801.jpg[/IMG]
Getting there...
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306709615.jpg[/IMG]
Done...
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1306709613.jpg[/IMG]
I think I need to do some datalogging and have Mick look it over, it idles a little funky and it smells like it's running rich.
Plus when I pull up to a stop it sounds like it wants to die. The LT4 hotcam isn't that aggressive is it?
We had fun with the bellhousing bolts, found out that a 9/16" ratchet wrench, a 24" extension and a ratchet that pivots at the head are all very valuable for this job.
Thank you guys for all the advice and encouragement.
GURU'S ROCK!!
Jeff
Posted on: 2011/5/30 1:10
22806 Posts
Congratulations on a job well done!
One suggestion I would like to make is to get some spark plug heat boots - I like the ones I have.
As far as the idle, did you do the base idle / TPS reset procedure? If so, you might need to bump it up 50-100 rpm at the base with the bigger cam.
Now bask in your glory
Posted on: 2011/5/30 2:55
rklessdriver Re: Dreaming of a new engine
Congrats Jeff.
Glad to see you got everything in and running.
Posted on: 2011/5/30 15:43
High Point, NC
1440 Posts
I'm not sure what the tps reset procedure is. Do I just check the voltage across the pins or is there something else I need to do?
Where did you get your boots?
I checked the timing again today it's right on 6 btdc.
Posted on: 2011/5/30 19:53
High Point, NC
1440 Posts
rklessdriver wrote:
Congrats Jeff.
Thanks Will. I can' thank you enough for all your advice!!!
Posted on: 2011/5/30 19:55
22806 Posts
Jeff, I didn't forget you. I'm just not at home on my computer with the correct procedure.
Boots can be found at Summit for a good price.
Posted on: 2011/6/2 2:00
High Point, NC
1440 Posts
It's all good Matthew. Whenever you get a chance.
Posted on: 2011/6/2 11:06
mseven Re: Dreaming of a new engine
Motor City Madhouse
247 Posts
There is no TPS re-set method as the 90-91 is non-adjustable. In this case it's use reflects % of throttle angle unlike the MAF cars (m.v. vs. fueling in some aspects).
If refering to Min Air adjust, follow the same as I posted over in Big Grizzly's thread..The reason includes your idle being higher/modified than stock threfor counts need to be approx. 40 (your scan showed 68 P/N @operating temp).
Posted on: 2011/6/2 11:37
22806 Posts
Mick is right. I forgot what year you had, the TPS is not adjustable. The ECM checks the voltage at start up and adjusts based on that. You can still ohm it to make sure it's in range. So if you already set your min air and IAC you're in business.
Posted on: 2011/6/2 11:45
High Point, NC
1440 Posts
Thanks Mick, I will do that tonight.
Spent an hour fooling with the one hood latch mechanism last night since it decided to stop releasing.
Matthew, thanks for trying to help. TPS volts showed .57 when datalogging I think.
I can't wait to start driving it!!!
Posted on: 2011/6/2 12:16
Impressive! Bet you'll be glad when everything's sorted out.
There will always be something to fool around with, like a balky hood release. Keeps it interesting.
Posted on: 2011/6/2 13:02
22806 Posts
Photobucket
Posted on: 2011/6/3 2:14
High Point, NC
1440 Posts
That is interesting that it says the TPS idle voltage for 90-91 should be .72 mine is at .57 according to datamaster.
Thanks for posting it Matthew.
Didn't get to mess with the car last night. Had homework. Why did I take a summer class?
Posted on: 2011/6/3 10:53
High Point, NC
1440 Posts
Pulled the IAC out last night to make sure it wasn't full of carbon. It was nice and clean.
Drove the car up to operating temp and then messed with the IAC counts. Got them down to 40. The in gear idle is much better now.
Posted on: 2011/6/6 14:21
« 1 (2)
