Eagle223usa | Need an LT4 Guru! | ||
Guru with Eyes of Steel
Any LT4 owner know if the original LT4 springs had dampers inside them? I just bought a set from Pace and sent them to my machinist. They came without the internal damper. When I asked if he would use the original dampers he stated that if it needed a damper GMPP would have sent them with the springs. Anyone know? What is the dampers purpose in life anyways? Do I need it? Thanks.
Posted on: 2011/7/24 22:47
God Bless America! |
bogus | Re: Need an LT4 Guru! | ||
I am checking the Helm right now and don't see anything special.
Posted on: 2011/7/24 22:58
rklessdriver | Re: Need an LT4 Guru! | ||
GM factory LT4 springs do NOT have a flat wire damper.
The damper is to reduce spring harmonics. When GM started the LT1/4's one of the big technical advances was in the valve springs. They used a special type of wire that had an ovate crosssection (as oposed to round). The ovate wire springs did not need a damper to keep the spring harmonics under control. Will |
Posted on: 2011/7/25 0:36
Eagle223usa | Re: Need an LT4 Guru! | ||
Groovy! Thanks Bogus and Reckless, I just never seen one on a SBC without it. I should learn to trust my engine builder. Thanks Guys.
Posted on: 2011/7/25 0:45
RickAnthony | Re: Need an LT4 Guru! | ||
ASE Master Certified
Cool to know about the spring design... I was thinking back when I installed my take off LT4 heads didn't recall seeing one either, but that was years ago..
Posted on: 2011/7/25 1:03
BrianCunningham | Re: Need an LT4 Guru! | ||
They're also nice if the spring breaks, keeps the valve out of the piston.
Posted on: 2011/7/25 1:15
You mean having a damper, right Brian? |
Posted on: 2011/7/25 19:00
MK 82 | Re: Need an LT4 Guru! | ||
It is just a second smaller spring. Never heard it called a dampner. They are not used as much anymore.
Posted on: 2011/7/28 4:28
96 CE Roadster LT4 |
