148 user(s) are online (106 user(s) are browsing Forums)
Transverse Leaf Spring
Eagle223usa Puddle on the floor.....Damn.
Guru with Eyes of Steel
God's country, Pa
197 Posts
Came out to drive the Vette to work this afternoon and found a puddle of DOT 3 under the car. Has anyone heard of a slave cylinder blowing out while sitting in the garage? I didn't get a chance to get under her, could be the resivour but couldn't tell. Oh well,it begins again......
Posted on: 2011/8/2 0:35
God Bless America!
bogus Re: Puddle on the floor.....Damn.
20860 Posts
where was the puddle?
Posted on: 2011/8/2 1:14
jaa1992 Re: Puddle on the floor.....Damn.
Stone Mtn, GA (near Atlanta)
187 Posts
Been there - done that.
Before I replaced my slave I was adding clutch fluid weekly.
Posted on: 2011/8/2 1:59
istter1 Re: Puddle on the floor.....Damn.
Bakersfield Ca
2336 Posts
Was there a time when you pushed on the peddle and you felt it was stiffer and then worked ok?
Steve
Posted on: 2011/8/4 16:20
Eagle223usa Re: Puddle on the floor.....Damn.
God's country, Pa
197 Posts
Well. Finally got her on a lift, She needed inspected anyways. The puddle turned out to be coolant, One of the water pump bolts is leaking. That was a relief. I then told my buddy, who is an inspection mechanic to just inspect it. FAILED, Ouch. I now need 2 rear wheel bearings and 2 outer tie rod ends and that means an alignment too. Can anyone recommend a good wheel bearing? Delco's are out of this world in price, if you can find them! I was happy just driving along in my car trying to forget about spending all last summer with her on jackstands. Steve, No I didn't but the weekend before me and the Wife had a moment together when an F150 pulled out in front of us on Rt51 just past Whited st. and I had to stand her on her nose. GOD bless Hawks pads! Jaa, I was standing by to replace the slave. I already have a new GM one on the parts shelf. I plan on going Moog for the front tie rod ends, but dont know about the rears. Thanks for the replies Guys!
Posted on: 2011/8/7 16:51
God Bless America!
Bakersfield Ca
2336 Posts
Everone of my friends in Bakersfield complained about how much I paid for Hawk Pads. I was going to put in the C5 system. After about a week of driving with Hawk Pads I had a simular thing happen. Love those pads.
I am waiting on a replacement transmission for my DN4+3 transmission. Can feel the money pain.
Steve
Posted on: 2011/8/7 17:35
God's country, Pa
197 Posts
Money spent on brakes is never wasted! Much cheaper and less dramatic than bodywork! I've been doing searches on rear wheel bearing and it seems that some teflon washers can be be replaced and the things tightened up???? What are SKF's anyhow? I don't have time for another search today as I have to go to work, In my truck. Damn.
Posted on: 2011/8/7 17:57
God Bless America!
1Fast04Vert Re: Puddle on the floor.....Damn.
SKF is a manufacturer and seem to be the best choice for C4 bearings.
There is one teflon washer each side, available only at the dealer. If the washers disintegrate you will likely get a clicking noise.
Hubs are sealed and tightening them up is a very temporary fix, if it fixes them at all.
Posted on: 2011/8/7 21:45
God's country, Pa
197 Posts
Would anyone have part numbers on those washers?
Posted on: 2011/8/7 22:45
God Bless America!
rayquayle Re: Puddle on the floor.....Damn.
139 Posts
Posted on: 2011/8/7 23:25
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
God's country, Pa
197 Posts
Ray, You Sir are a model of speed and precision. Nicely done. And Thanks.
Posted on: 2011/8/8 16:16
God Bless America!
God's country, Pa
197 Posts
Are 1990 rear wheel bearings compatable with a 1995 car? Thanks!
Posted on: 2011/8/8 17:05
God Bless America!
Not sure about that. Here is the part number for the rear hub in SKF for a '95 model: SKF Part # BR930024. I looked around before I bought mine and bought from Rock Auto using their link here on the site. Be sure to enter the discount code for an extra 5% off.
Posted on: 2011/8/8 17:41
187 Posts
For the rear they should be the same part number for 88 and up.
If you need to replace your rear outer tie rod ends - moog is the answer. Any tie rod end or ball joint - moog is the answer.
SKF or Timken for the hub assembly - its going to be expensive. But I'd rather change a c4 rear hub than a c5 rear hub. You don't have to take apart as much of the rear suspension to change the c4 hub.
Posted on: 2011/8/8 20:19
God's country, Pa
197 Posts
I went with SKF for the bearings and Moog for the ends. And yes, It was exspensive. I have Friday off and I know how I'm spending it. Thanks for the advice.
Posted on: 2011/8/11 2:58
God Bless America!
Matatk Re: Puddle on the floor.....Damn.
22810 Posts
Bearings are a pretty easy swap, just have a good sized breaker bar in case the nut doesn't want to break loose.
Posted on: 2011/8/11 3:04
God's country, Pa
197 Posts
It didn't take that long using my buddy's lift. The spindle nuts were loose. Someone had already been in there. The washers were greased but the splines were dry and rusty. I cleaned it all up and greased it with Hi temp grease and added the new washers. When I got it home I backed it in and out of my garage (the only time I could hear the "clicking") and no clicks! I was meticulous with the torque settings. Now I just need to get her alignment checked and I'm rolling again. Thanks to all you guys for your input.
Posted on: 2011/8/13 16:45
God Bless America!
