140 user(s) are online (108 user(s) are browsing Forums)
VtVette '90 - '93 directional switch questions
Las Vegas, NV
357 Posts
hello all, the directioal stalk in my '93 broke the other day. It appears the stalk in the correct orange lettering is no longer available. As it seems to purchase new i'm looking at white lettering does anyone know if this is a common directional stalk found in any GM vehicle from that period or, do I need to buy one specific for the later C4 Corvette?
thanks,
Posted on: 2011/7/28 3:09
Brian
VTvette
tjpreul Re: '90 - '93 directional switch questions
I know that one from a Camaro will work. I would believe that one from a Blazer or truck should work too.
Posted on: 2011/7/28 3:22
josephf31 Re: '90 - '93 directional switch questions
New Jersey
375 Posts
thanks,
eBay. or Jason at vette2vettec.com has just about everything, reasonable prices, great service, great guy.
Posted on: 2011/7/28 4:38
bogus Re: '90 - '93 directional switch questions
the stalk broke? not the multi-function switch?
Posted on: 2011/7/28 5:49
VtVette Re: '90 - '93 directional switch questions
Las Vegas, NV
357 Posts
Andy after further research I believe the multi-function switch is exactly what is broken.
Does anyone have the GM number for this? I've searched all the popular corvette parts sellers but cannot find one on their sites.
I have found the "turn signal switch", the large white plastic switch inside the column but I do not believe this is actually the multi-funcion switch. The multi-function switch is what activates the directional switch correct?
Thanks Andy for your help,
Posted on: 2011/7/28 14:21
Brian
VTvette
Las Vegas, NV
357 Posts
I think I found it:
http://www.ecklerscorvette.com/corvet ... mer-switch-1990-1993.html
Could someone please confirm this is the "multi-switch"?
Thanks again,
Posted on: 2011/7/28 14:58
Brian
VTvette
BillH Re: '90 - '93 directional switch questions
Yea, Brian, that is the one the stalk goes into per the exploded drawing in the FSM (3F5B-2).
Controls wipers, cruise,etc. The turn signal switch is further up in the column.
Note: pull the airbag fuse before working on it.
Posted on: 2011/7/28 15:15
You will need to remove the airbag, wheel, clock spring...
I have done this, and it is much easier if the column is on a bench.
Remove the wheel and airbag. Then, remove the column from the car and finish the project on the bench.
I would also replace the tilt wheel pivot pins and springs.
Posted on: 2011/7/28 16:27
Las Vegas, NV
357 Posts
Thanks Guys - I've gone one coming.
Thanks for the tip's. I've spent time in many a GM column so,
I'm pretty familiar with them. Specifically the C4's.
Strange of all the C4's I've owned I've had more than a few with the steering column wobble I've fixed but, never had a multi-switch break. Seems it's a pretty common problem on the C4.
Posted on: 2011/7/28 16:44
Brian
VTvette
And I don't know why... it's the same switch used in many other GM vehicles...
What breaks is this metal ridge that acts on the turn signal cancellation cam.
Posted on: 2011/7/28 17:36
Las Vegas, NV
357 Posts
Yeah Andy that is a good question. I've owned many GM trucks from the late 80's to mid 90's, several with more than 200,000 miles and never once had a problem. I would bet it's the same column internals.
Posted on: 2011/7/28 18:30
Brian
VTvette
finderhome Re: '90 - '93 directional switch questions
Redondo Beach
17 Posts
I have the same problem and can anyone tell me where to get the replacement part.
Posted on: 2011/8/16 1:48
New Jersey
375 Posts
For any great used parts go to www.vette2vette.com Jason there rocks!
Posted on: 2011/8/16 2:01
Redondo Beach
17 Posts
Thanks for your suggestion!!!! I ordered the part today. It was 1/2 the price for the multi-function switch. Thanks again
Posted on: 2011/8/17 1:51
New Jersey
375 Posts
Glad I could help, this forum introduced me to Jason and a pretty good percentage of the parts in my 'Vette came from him!
Posted on: 2011/8/17 2:00
