114 user(s) are online (59 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
1Fast04Vert drip tab question
Do I need to trim all of them, or just the center ones, when going to 1.6 rockers? I am putting LT1 covers on an LT4 head.
Then there are short 'tubes' that appear to thread into the heads that the centerbolt valve cover bolts go thru. Do those tubes simply unthread out of the heads?
Posted on: 2011/9/7 18:56
pianoguy Re: drip tab question
Can't help you on the drip tab question, but yes, those standoffs just thread into the heads. The valve cover bolts are stubby little buggers and screw into the standoffs.
Posted on: 2011/9/7 19:06
biggrizzly Re: drip tab question
I removed all of them. I think the covers are the same but might be wrong.
Posted on: 2011/9/7 19:21
BrianCunningham Re: drip tab question
Trim all
did this on my friend's LT1
Posted on: 2011/9/7 19:55
1Fast04Vert Re: drip tab question
Thanks guys, I appreciate the replies.
Posted on: 2011/9/7 19:57
I just grabbed them with a good pair of pliers at the base of the tab and broke each one off. No mess, no fuss. I could have used a little cut-off wheel but the pliers worked great. I won't be responsible for broken valve covers, but it really worked well for me that way.
Posted on: 2011/9/7 20:13
Thanks Don. The dremel took the off in less than a minute.
Posted on: 2011/9/7 20:34
Strick Re: drip tab question
Lake Wylie, SC
129 Posts
That's what I did, used a Dremel tool and a small cut off wheel. I like the Mag valve covers as you can powder coat them and they stay clean. Mine are even flamed. The standoffs are already in the mag covers.
Posted on: 2011/9/8 22:25
