156 user(s) are online (44 user(s) are browsing Forums)
Does it work?
biggrizzly OBDII Scan tool for C5 Z06
From a friend of mine in the Corvette Club... What do you C5 ODBII guys recommend for him? See his question below.
"Guys, I’m looking to buy a code scanner to be able to troubleshoot and fix DTC’s. I’ve seen a few OBD II CAN compatible units on eBay and they run from $98.00 to $160.00. Do you have any recommendations on which unit to purchase?"
Posted on: 2011/9/7 19:04
Matatk Re: OBDII Scan tool for C5 Z06
22983 Posts
This is the one I have:
http://www.autobarn.net/actron-obd-scanner-cp9180.html
Probably more than what most people need, even me. But it runs state emissions tests if you have those so it's nice. It can monitor O2 sensor data and do freeze frames.
I can't comment on other ones, I haven't used them.
Posted on: 2011/9/7 22:45
crash Re: OBDII Scan tool for C5 Z06
WRIGHT CITY MO 63390
977 Posts
i use a monitor 4000. it has quite a bit of stuff. one of my many tools from when i was wrenching for a living. does what i need to do.
Posted on: 2011/9/7 23:24
BillH Re: OBDII Scan tool for C5 Z06
I have the least expensive Autoxray, works fine. Doesn't doo all the things that Matt's does but, you get a code, find it on the web & fix the problem.
Mine will reset the SES but that also clears the emmission monitors which take some days of driving the car to reset them for a smog check.
It does what I need.
Posted on: 2011/9/8 0:04
Ultraman Re: OBDII Scan tool for C5 Z06
15514 Posts
I'm a little confused, I didn't think a C5 ever threw a code..................
I'm sure that will come back to haunt me......
Posted on: 2011/9/8 2:21
22983 Posts
Yeah, I'll be keeping this one in the file....
Posted on: 2011/9/8 2:31
teebee Re: OBDII Scan tool for C5 Z06
12798 Posts
I have the AutoXray 6000, you know, I haven't had to use it on the C5 yet....I'm sure my time is coming though.
Posted on: 2011/9/8 2:44
RickAnthony Re: OBDII Scan tool for C5 Z06
ASE Master Certified
Downers Grove, IL
703 Posts
Was he looking for just a code reader or for a scan tool with some data? You can pull & clear trouble Codes through the instrument cluster on all modules, no tools needed.. but for data a scan tool would be needed..
-=Rick
Posted on: 2011/11/14 5:08
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
