248 user(s) are online (191 user(s) are browsing Forums)
TommyT-Bone, more...
383tpimachine 32lb injector limit?
Corpus Christi
976 Posts
What power can my 32 lb injectors support on boost?
Plan on adding a vortec but dont know if I will need bigger injectors (yet). I am putting down around 375rwhp now and plan to add 5-7lbs of boost on top.
Posted on: 2011/10/4 20:48
1970 El Camino-Awaiting LSX
Jonnymac Re: 32lb injector limit?
Decatur, Illinois
25 Posts
I'm make 422 at the rear using 255 lp pump with 32 lb injectors @ 43.5 and running at 80% duty cycle.
Posted on: 2011/10/18 9:24
383tpimachine Re: 32lb injector limit?
Corpus Christi
976 Posts
So I will need new injectors. Thanks
Posted on: 2011/10/18 21:19
FICINJECTORS Re: 32lb injector limit?
Gold Sponsor Vendor
117 Posts
on a mild supercharged engine the 32's will top out at about 375CHP
Posted on: 2011/10/19 1:15
Corpus Christi
976 Posts
Im at 400rwhp now. I will add the sc when I build a new engine and do it all at once. What size inj will support 700rwhp at 85% DC?
Posted on: 2011/10/19 16:44
Gold Sponsor Vendor
117 Posts
auto or manual?
Posted on: 2011/10/19 19:48
Corpus Christi
976 Posts
Manual. 6800rpm redline.
Posted on: 2011/10/20 1:04
AKS_Racing Re: 32lb injector limit?
62 Posts
What all have you done to your '85 to deliver almost 500FWHP? Just curious.
Posted on: 2011/10/20 1:27
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft:
Corpus Christi
976 Posts
Highly ported HSR, heads, cam, 383, 10.75cr, this that and a generous dyno.
Dyno said 406rwhp and 445rwtq. More than likely it is 370-375rwhp and 420-430tq.
I can pull a 12.1 sec ls1 camaro by half a car shifting correctly. Car is setup for autox and roadracing however which is why my goal is just 600-650. Anymore I doubt I could handle it.
Im talking with TEA to make me some heads that flow what I want on a bigger (4.125) bore at 9.5 cr. Im in the process is specing my 400ci boost ready motor.
Posted on: 2011/10/20 3:33
Gold Sponsor Vendor
117 Posts
For that RWHP on a supercharged engine you will need 75lb injectors minimum to get an 80% DC.
In that area I have 72lb Siemens mods, and our 80lb Siemens mods. Price for either is $399 for the set of 8, flow matched within 1%, viton o-rings installed, and a 1 year no questions warranty.
Shipping as always is a flat $7
Posted on: 2011/10/21 0:04
Corpus Christi
976 Posts
72 will be the ticket. When it comes time to order I will be getting in touch. Thanks for your time and help. My bosch 3s are badass btw
Posted on: 2011/10/21 4:22
