305 user(s) are online (260 user(s) are browsing Forums)
Ultraman, vetteblondie, more...
383tpimachine 32lb injector limit?
Corpus Christi
976 Posts
What power can my 32 lb injectors support on boost?
Plan on adding a vortec but dont know if I will need bigger injectors (yet). I am putting down around 375rwhp now and plan to add 5-7lbs of boost on top.
Posted on: 2011/10/4 20:48
1970 El Camino-Awaiting LSX
Jonnymac Re: 32lb injector limit?
Decatur, Illinois
25 Posts
I'm make 422 at the rear using 255 lp pump with 32 lb injectors @ 43.5 and running at 80% duty cycle.
Posted on: 2011/10/18 9:24
383tpimachine Re: 32lb injector limit?
Corpus Christi
976 Posts
So I will need new injectors. Thanks
Posted on: 2011/10/18 21:19
FICINJECTORS Re: 32lb injector limit?
Gold Sponsor Vendor
117 Posts
on a mild supercharged engine the 32's will top out at about 375CHP
Posted on: 2011/10/19 1:15
Corpus Christi
976 Posts
Im at 400rwhp now. I will add the sc when I build a new engine and do it all at once. What size inj will support 700rwhp at 85% DC?
Posted on: 2011/10/19 16:44
Gold Sponsor Vendor
117 Posts
auto or manual?
Posted on: 2011/10/19 19:48
Corpus Christi
976 Posts
Manual. 6800rpm redline.
Posted on: 2011/10/20 1:04
AKS_Racing Re: 32lb injector limit?
62 Posts
What all have you done to your '85 to deliver almost 500FWHP? Just curious.
Posted on: 2011/10/20 1:27
Miss Nasty: Bigger SBC with C4SP and just shy of 30 psi boost. Low 9.0s with low 160+MPH with a decent 60' (1.72 is decent for me these days). :thumbleft:
Corpus Christi
976 Posts
Highly ported HSR, heads, cam, 383, 10.75cr, this that and a generous dyno.
Dyno said 406rwhp and 445rwtq. More than likely it is 370-375rwhp and 420-430tq.
I can pull a 12.1 sec ls1 camaro by half a car shifting correctly. Car is setup for autox and roadracing however which is why my goal is just 600-650. Anymore I doubt I could handle it.
Im talking with TEA to make me some heads that flow what I want on a bigger (4.125) bore at 9.5 cr. Im in the process is specing my 400ci boost ready motor.
Posted on: 2011/10/20 3:33
Gold Sponsor Vendor
117 Posts
For that RWHP on a supercharged engine you will need 75lb injectors minimum to get an 80% DC.
In that area I have 72lb Siemens mods, and our 80lb Siemens mods. Price for either is $399 for the set of 8, flow matched within 1%, viton o-rings installed, and a 1 year no questions warranty.
Shipping as always is a flat $7
Posted on: 2011/10/21 0:04
Corpus Christi
976 Posts
72 will be the ticket. When it comes time to order I will be getting in touch. Thanks for your time and help. My bosch 3s are badass btw
Posted on: 2011/10/21 4:22
