200 user(s) are online (145 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
pappyfreebird in minnasota
1028 Posts
where to have a 4+3 rebuilt??? the dudes in a barn id mentioned earlier has no overdrive...and he said they weldid somethin together to git him home n now ony has 4spd...so he lets it set...who still works on these and anybody close in mn.???
Posted on: 2008/2/3 19:38
Stl94LT1 RE:in minnasota
128 Posts
WOW, you live in Minnesota and don't even know how to spell it correctly!!
Sorry, I couldn't resist.
Posted on: 2008/2/3 19:44
bogus RE:in minnasota
good question... but there are other questions that need to be asked.
Are we SURE the OD unit is bad? Many times, wiring is the cause... not mechanical.
If it was my car, I would seriously consider upgrading to the TKO 5spd. It's got the same ratios, but in a more modern 5spd package without the OD unit.
It is more expensive, but I believe it will make a much nicer driving car.
pianoguy RE:in minnasota
I've heard this is a good shop, but I don't have any experience with them, and I'm not sure if they work on transmissions:
http://www.boosperformance.com/
Posted on: 2008/2/3 20:25
pappyfreebird RE:in minnasota
1028 Posts
1st that spellin were jus ta see ifn yad notice!!!
bog there are lots of questions... im getting secondhand bs n trin to pass it on and help the guy.... my freind jus said he was in the cities n the cats od quit werkin so this shop weldid somthing to get them home n now car ony has 4 spd ...sarry ill try n find out more ...but am hearing more n more they dont repair a 4+3 anywhere ...n that spookes me too knowing i have one myself
Posted on: 2008/2/3 20:29
1028 Posts
i emailed boos ...thanks ...now i wait n see what they say... ill post when hear...the minnisodee ilitterated pappy freebid dayum meant freebird!!!
Posted on: 2008/2/3 20:36
Notorious RE:in minnasota
It'll probably be awhile before they respond. They'll have to find an interpreter first.
Posted on: 2008/2/3 20:41
MK 82 RE:in minnasota
Palm Beach Gardens, FL
439 Posts
Translation!!
Bogus, there are lots of questions. I am getting secondhand bullshit and trying to pass it on and help the guy. My friend just said he was in the cities and the gentleman's overdrive quit working so this shop welded something to get them home and now the car only has 4 speeds. Sorry, I'll try and find out more but am hearing more and more they don't repair a 4+3 anywhere and that spooks me too knowing that I have one myself.
Eddie's hillbilly translation service!
Posted on: 2008/2/3 20:51
96 CE Roadster LT4
1028 Posts
yer awright drop t and thats a hick fact brutha!!!!
Posted on: 2008/2/3 20:57
Oaklands RE:in minnasota
Morristown, TN
480 Posts
You forgot to put in all the Ay's you MN people made famous. :shaking:
Posted on: 2008/2/3 22:20
