288 user(s) are online (214 user(s) are browsing Forums)
Assembly Line Diagnostic Link
smooth Roller Rockers mfg?
Formerly "Aquavet" in Pa.
386 Posts
Anyone know who makes Summit's roller rockers?
Posted on: 2008/2/8 0:24
Alan
2001 Navy Blue Metallic
smooth RE:Roller Rockers mfg?
386 Posts
If noone knows, then I guess I'll save up a few more bucks and get the CCs or Cranes. It was just a thought. I have the "do something to the Vette" itch and for 10 or 12 horses I was going to waste an afternoon on it.
Thanks anyway gang.
Damn "Askers" !!!!! wish they'd stop posting this crap.!
Posted on: 2008/2/8 12:08
Alan
Notorious RE:Roller Rockers mfg?
I'd call them and ask them. If they hee-haw around the answer, then you'll know for sure to steer clear. I'd be afraid they were Proforms or some other Chinese junk.
Posted on: 2008/2/8 13:23
I hate sporks...
jsup RE:Roller Rockers mfg?
1778 Posts
I have heard it was Scorpion. Again "heard".
Posted on: 2008/2/8 13:28
dan0617 RE:Roller Rockers mfg?
I have summit 1.6 rockers on my L98 engine. I have had good luck with them. I actually didn't know I had to remove the drip tabs from the valve covers when I installed them. The drip tabs broke off and wedged between the rocker nut and the top of the rocker arm slot. When I fired it up it instantly bent all of my pushrods (some of them really bad, kind of like a big fishing hook) and 1/2 of my rocker studs. A few of the pushrods were so bad I almost couldn't get them up out of the heads. I bent the studs back straight, put in new pushrods, and cleaned the pieces of aluminum out of the heads. There are a few little nicks on the rockers where the drip tabs got pinched, other than that they are as good as new. I can't believe none of them broke. I also can't believe none of the lifters got trashed.
Posted on: 2008/2/8 18:07
sprint7677 RE:Roller Rockers mfg?
Oxford, Pa
127 Posts
Thanks anyway gang.
I used Comp Cams 1.6's, they worked fine in my crossfire motor
Posted on: 2008/2/8 19:52
1984 Corvette mostly stock, many new parts
386 Posts
I tried to contact the guys at summit and here is the reply I got:
Subject
Mfg. of SUM-G6936-16
Discussion Thread
Response (Zack) 03/06/2008 10:32 AM
Unfortunately, due to contract agreements we can't disclose who makes them. Thanks
Customer 03/05/2008 11:33 PM
I was wondering who produces your house brand roller rockers. Could you let me know
Posted on: 2008/3/7 1:23
Alan
Painterman Re: Roller Rockers mfg?
Athens, OH
10 Posts
I am installing Harland Sharp Roller Rockers in my 86 at this time. A friend of mine that I trust recommended them. They are none self aligning.
Posted on: 2008/3/7 13:03
Mekanic RE:Roller Rockers mfg?
Tampa Bay Florida
827 Posts
If it is I would give them a try. I've only heard good things about Scorpion.
Posted on: 2008/3/7 16:36
~Rich
Polo LT4
1778 Posts
Call Scorpion and ask them OR just buy Scorpion. They are decent rockers.
I went with the Chrome MOlly ones since they are stronger. The comp pro mags....but they are more money than aluminum.
Posted on: 2008/3/8 9:16
