143 user(s) are online (101 user(s) are browsing Forums)
smooth Roller Rockers mfg?
Formerly "Aquavet" in Pa.
386 Posts
Anyone know who makes Summit's roller rockers?
Posted on: 2008/2/8 0:24
Alan
2001 Navy Blue Metallic
smooth RE:Roller Rockers mfg?
386 Posts
If noone knows, then I guess I'll save up a few more bucks and get the CCs or Cranes. It was just a thought. I have the "do something to the Vette" itch and for 10 or 12 horses I was going to waste an afternoon on it.
Thanks anyway gang.
Damn "Askers" !!!!! wish they'd stop posting this crap.!
Posted on: 2008/2/8 12:08
Alan
Notorious RE:Roller Rockers mfg?
I'd call them and ask them. If they hee-haw around the answer, then you'll know for sure to steer clear. I'd be afraid they were Proforms or some other Chinese junk.
Posted on: 2008/2/8 13:23
I hate sporks...
jsup RE:Roller Rockers mfg?
1778 Posts
I have heard it was Scorpion. Again "heard".
Posted on: 2008/2/8 13:28
dan0617 RE:Roller Rockers mfg?
I have summit 1.6 rockers on my L98 engine. I have had good luck with them. I actually didn't know I had to remove the drip tabs from the valve covers when I installed them. The drip tabs broke off and wedged between the rocker nut and the top of the rocker arm slot. When I fired it up it instantly bent all of my pushrods (some of them really bad, kind of like a big fishing hook) and 1/2 of my rocker studs. A few of the pushrods were so bad I almost couldn't get them up out of the heads. I bent the studs back straight, put in new pushrods, and cleaned the pieces of aluminum out of the heads. There are a few little nicks on the rockers where the drip tabs got pinched, other than that they are as good as new. I can't believe none of them broke. I also can't believe none of the lifters got trashed.
Posted on: 2008/2/8 18:07
sprint7677 RE:Roller Rockers mfg?
Oxford, Pa
127 Posts
Thanks anyway gang.
I used Comp Cams 1.6's, they worked fine in my crossfire motor
Posted on: 2008/2/8 19:52
1984 Corvette mostly stock, many new parts
386 Posts
I tried to contact the guys at summit and here is the reply I got:
Subject
Mfg. of SUM-G6936-16
Discussion Thread
Response (Zack) 03/06/2008 10:32 AM
Unfortunately, due to contract agreements we can't disclose who makes them. Thanks
Customer 03/05/2008 11:33 PM
I was wondering who produces your house brand roller rockers. Could you let me know
Posted on: 2008/3/7 1:23
Alan
Painterman Re: Roller Rockers mfg?
Athens, OH
10 Posts
I am installing Harland Sharp Roller Rockers in my 86 at this time. A friend of mine that I trust recommended them. They are none self aligning.
Posted on: 2008/3/7 13:03
Mekanic RE:Roller Rockers mfg?
Tampa Bay Florida
827 Posts
If it is I would give them a try. I've only heard good things about Scorpion.
Posted on: 2008/3/7 16:36
~Rich
Polo LT4
1778 Posts
Call Scorpion and ask them OR just buy Scorpion. They are decent rockers.
I went with the Chrome MOlly ones since they are stronger. The comp pro mags....but they are more money than aluminum.
Posted on: 2008/3/8 9:16
