133 user(s) are online (77 user(s) are browsing Forums)
bam LT1 oil pan gasket differences FYI
missouri
250 Posts
Last spring I did a hot cam swap and ordered an oil pan gasket Victor Renz OS32496B (it is tied to GM part #8101086760 in the catalog) When I tried to install it (under my 93 vett, motor still in the car) it didn't look right. It started to leak immediately (yes I properly torqued all bolts). After about a month I pulled it off and covered the whole gasket, both sides with the "right stuff" and re installed. I was fine for about a month then began leaking again. This winter I rebuilt my whole motor and ordered a GM gasket # 8101086760. When installing it I noticed how the fit was much better than the Victor Renz gasket. No leaks! Here are pictures to show the physical differences between the two gaskets, they are NOT the same. One may work as well as the other in some cars, but it didn't in mine. Just trying to save someone the hassle of trying to change the gasket, especially when the motor is still in the car (if you have done it you know what fun it is) with a gasket that might not work, that is physically not the same gasket as the GM one. Hope this helps someone, wish I could of know this before and just ordered GM to start with. By the way the fel-pro gasket is exactly the same as the VR gasket and both are not the same as the GM gasket, stick with the GM if you want to be safe.
Forgot to add; VR gasket is grey, GM black.
jpg  IMG_4291.JPG (52.38 KB)
2992_4f43b52be6b14.jpg 640X480 px
jpg  IMG_4292.JPG (54.09 KB)
2992_4f43b538e9890.jpg 640X480 px
Posted on: 2012/2/21 15:29
BillH Re: LT1 oil pan gasket differences FYI
I understand what you're saying, Tom.
My only comment is that I've done 2 Felpro's on LT1's, installed completely dry. Zero leaks after 3 years, the underside of my car is dry and clean.
Posted on: 2012/2/21 16:03
bam Re: LT1 oil pan gasket differences FYI
missouri
250 Posts
There must be some slight differences in motors that make the thicker gaskets leak while on other cars they are fine, a mystery??!! I forgot to mention that the lower photo shows that the GM gasket, under the timing cover is almost 1/4" thinner than the Victor Reinz, it is also thinner around the rear main seal than the VR, that is what I believe caused the leak on my car because that is where oil ran out.
Posted on: 2012/2/21 17:48
bam wrote:
There must be some slight differences in motors that make the thicker gaskets leak while on other cars they are fine, a mystery??!! .
Hard to say unless the pan got a bit tweeked at initial assembly.
I do know that the differences in the brake line crossover placement makes it difficult or easy to get the pan off.
BTW, the Felpros I've used were blue.
http://www.summitracing.com/parts/FEL-OS34500R/
Posted on: 2012/2/21 18:07
bogus Re: LT1 oil pan gasket differences FYI
20861 Posts
I have used Felpro, but still have a minor drip in the front.
Posted on: 2012/2/21 19:42
It's real easy not to get the gasket lip totally over the pan, and it's hard to see. I use a very small, flat blade screwdriver to run the outer edge of the gasket where it meets the curved front of the pan with the bolts loose.
Posted on: 2012/2/21 20:08
Matatk Re: LT1 oil pan gasket differences FYI
22812 Posts
Good tips in here.
Posted on: 2012/2/22 0:37
missouri
250 Posts
I didn't actually try the fel-pro. When I saw how far off the fit of the VR gasket was I went to the local O'Rilleys and asked to see a fel-pro, it was not blue, makes me wonder if a batch of gaskets got boxed wrong?
Posted on: 2012/2/22 1:14
There may be gray ones,Tom.
I use the first one at the top (blue).
I really like them.
http://www.summitracing.com/search/Pa ... ne-Type/V8/?Ns=Rank%7cAsc
Posted on: 2012/2/22 1:22
missouri
250 Posts
Good to know, about 1/2 the cost of the GM gasket.
Posted on: 2012/2/22 14:51
The nice thing about that set is it comes with gaskets and o=rings for the oil filter adapter.
The blue, plastic pieces are "gasket holders", they thread into the block at the front & rear (larger bolt holes), you then slip the gasket ovet the V part and they hold the gasket up against the block.
I had to cut down the front "holders" due to clearance with the crossmsmber but all in all, a neat idea.
Posted on: 2012/2/22 15:02
20861 Posts
I actually had the luxury of doing mine off the car... so there is no excuse! Except for a poor fitting gasket, or whacked out pan...
Posted on: 2012/2/22 16:50
rklessdriver Re: LT1 oil pan gasket differences FYI
A big problem with these one pc gaskets is that they are so grippy (can't think of any better way to describe it).
You can get leaks around the front and rear because the gasket grabs ahold of the timing cover and the rear main seal housing/adapter and it won't slide down fully against the gaps where they meet the block.
A dab of silicone in the "4 corners" will let the gasket slide down/seat fully and help fill in those gaps. You don't need much - think pencil eraser sized dab.
I've used the Fel Pro, Victor and Corteco/Detroit Gasket brand and never had a problem.
Posted on: 2012/2/22 17:50
SpectatorRacing Re: LT1 oil pan gasket differences FYI
Bill, Felpro changed to the gray color a year or so ago. I'm on about my 4th in that time. I never use the RTV in the corners, have done them on and off the car, and have no leak issues. Well...not around the oil pan gasket, anyway.
I did have one of the blue ones that was bad, (2 years ago?) there was mold flash along the top face. Easily found upon inspection.
Posted on: 2012/2/22 18:36
20861 Posts
It was a blue Felpro that blew out on me. I wish I could find the pictures... but... the gasket blew at the corners where the gasket drops down around the timing cover. Blew them out about perfectly.
Posted on: 2012/2/22 18:41
Blew out? Due to pressure?
Posted on: 2012/2/22 19:04
Could be but what I see is Fel-Pro QOS34407R is gray and
Fel-Pro QOS34500R is blue.
But that may have changed.
Posted on: 2012/2/22 20:26
Yea, that doesn't sound quite right especially since I'm going on 4 years.
Posted on: 2012/2/22 20:27
20861 Posts
I doubt it... There were signs of tearing at the turn, so I wonder if I over torqued it, causing the failure.
Posted on: 2012/2/22 23:51
I did use a torque wrench on the ones I did.
I went back under mine after a month, the torque held and clicked the wrench without turning the bolt.
It's certainly easy to "oversqueeze" things.
Posted on: 2012/2/23 0:31
missouri
250 Posts
The interesting thing to me about all this is the physical differences between the GM gasket and the VR. You can see if you look carefully at the lower pix that the GM (black gasket in the front) is shorter under the timing cover than the VR. Not only that but the GM gasket material that runs under the timing cover itself is actually thinner by about 1/8". When I put the VR gasket on for a dry fit the pan sat about 1/2" above the block where it should touch the rails of the block, I could stick my finger in there. When I tightened the pan down with the VR gasket the gasket bulged out in the front right under the timing cover, it was very obvious it did not seal right. That told me something was wrong and I didn't want to have to crawl under my vett after getting the motor back in to try and install another pan gasket, it is a job that will have you speaking lots of Chinese!
Also I went to the local auto parts store and looked at the Fel-pro #OS34500R and it is the same as the VR and different from the GM. and it was grey. The physical differences between the two gaskets is undeniable and obvious. I have had two of the VR gaskets now that did not fit, they came from Rock Auto. I can say that they were very good about returning the newest one that I did not install, even paying for return shipping!
This could be a fluke, but I really would not want to crawl under my car EVER again to replace that pan gasket ! I have done it twice!!
Posted on: 2012/2/24 14:52
Now, that's really strange. I wonder if Fel-Pro has changed and screwed up? The blue 500R fit correctly with no streatching at the timing cover.
Strange that both the fel-Pro and VR are like this.
Tom, do you remember if the VR fit at the rear main cap?
Maybe the gary ones are for a different small block timing cover/pan.
This wouldn't be the first time Fel-Pro made a mistake, they used to list LT1 valve cover gaskets as 92-96 and the 92's use the old style 91-earlier gaskets. But, it's hard to be an aftermarket mfg. and have every gasket for every car exactly right in a catalog.
Good info, Tom. We'll have to be careful.
Posted on: 2012/2/24 15:24
I just got a Fel Pro CS9966 which is the conversion set for the bottom end. It has the blue oil pan gasket.
Maybe it's just old stock.
Posted on: 2012/2/24 16:49
Yea, I almost feel like going out to Summit and looking at a 500R to see if it's blue (and buying it).
Posted on: 2012/2/24 16:53
missouri
250 Posts
"Tom, do you remember if the VR fit at the rear main cap?
Maybe the gary ones are for a different small block timing cover/pan."
No it did not fit well at the back of the pan either. I didn't lay the two gaskets back to back to compare that area, wish I would have now. I have also run into the valve cover mix up too. I am wondering if the two gaskets I got were actually for the older L98 block with the stamped steel timing cover??
Posted on: 2012/2/26 2:17
