133 user(s) are online (104 user(s) are browsing Forums)
Andrew High RPM Oil Pressure Drop, Round IV
Jefferson City, MO
447 Posts
WOOOHOOO! The new Canton oil pan is installed and no more oil pressure drop!! At WOT, right off idle, pressure is 60 and creeps up to 75 at redline. One question, where is "full" with a Canton 7 qt race pan?
The only problem was reinstalling the starter. With the new pan, I couldn't get the starter in, so I had to work it over the header collectors, after removing the O2 censor. Everything else is bolt on, if you take your time.
Thanks everyone for the advice. Now I'm ready for summer!
Posted on: 2012/3/4 21:07
2003 Atomic Orange Z06
SOLD 1979 4 Speed with 383
Calm Re: High RPM Oil Pressure Drop, Round IV
Vancouver, Canada
608 Posts
Posted on: 2012/3/4 21:22
marv02 Re: High RPM Oil Pressure Drop, Round IV
California City Ca
130 Posts
Posted on: 2012/3/4 21:25
Matatk Re: High RPM Oil Pressure Drop, Round IV
Maybe it's too simple, but why not just add 7 quarts? Will should chime in.
Posted on: 2012/3/4 22:28
Andrew Re: High RPM Oil Pressure Drop, Round IV
Jefferson City, MO
447 Posts
I knew someone would say that!
I put 7 qts in and the oil shows just below add on the dipstick. I have read that it should be 1/2 way between add and full. Right now, it has 7.5 qts (7 in pan and ~1/2 in the filter). So should 8 or 8.5 go in? I just want to be sure...
Thanks!
Posted on: 2012/3/4 22:46
Is that with Canton's dipstick or the stock GM? Is there a chance they are different?
Posted on: 2012/3/4 22:53
rklessdriver Re: High RPM Oil Pressure Drop, Round IV
The factory dipstick will read low with a Canton and many aftermarket pans because the aftermarket pans run the oil level lower in the sump to get it further away from the rotating assy.
Just make a note of where it reads with 7qts.
Glad it's fixed!
Posted on: 2012/3/4 23:05
California City Ca
130 Posts
I know getting to bolts going down the side rails above the oil pan kickout are fun ask me how I know this LOL.
Glad it worked out for you.
bogus Re: High RPM Oil Pressure Drop, Round IV
Excellent news!!!
Posted on: 2012/3/4 23:34
