Andrew | High RPM Oil Pressure Drop, Round IV | ||
WOOOHOOO! The new Canton oil pan is installed and no more oil pressure drop!! At WOT, right off idle, pressure is 60 and creeps up to 75 at redline. One question, where is "full" with a Canton 7 qt race pan?
The only problem was reinstalling the starter. With the new pan, I couldn't get the starter in, so I had to work it over the header collectors, after removing the O2 censor. Everything else is bolt on, if you take your time. Thanks everyone for the advice. Now I'm ready for summer! |
Posted on: 2012/3/4 21:07
2003 Atomic Orange Z06 Sold - 1996 Competition Yellow LT4 - DRM 383, NX N2O, Line Lock, LT Headers, 3" stainless exhaust, Power Effects, and many more mods SOLD 1996 Competition Yellow LT4 SOLD 1979 4 Speed with 383 |
Calm | Re: High RPM Oil Pressure Drop, Round IV | ||
Posted on: 2012/3/4 21:22
1995 Forged 385 ZF6 227/234 1.6 FIC30# MSD BBK SS SLP Bullets X-Pipe DynoMax |
marv02 | Re: High RPM Oil Pressure Drop, Round IV | ||
Posted on: 2012/3/4 21:25
Matatk | Re: High RPM Oil Pressure Drop, Round IV | ||
Maybe it's too simple, but why not just add 7 quarts? Will should chime in.
Posted on: 2012/3/4 22:28
Andrew | Re: High RPM Oil Pressure Drop, Round IV | ||
I knew someone would say that!
I put 7 qts in and the oil shows just below add on the dipstick. I have read that it should be 1/2 way between add and full. Right now, it has 7.5 qts (7 in pan and ~1/2 in the filter). So should 8 or 8.5 go in? I just want to be sure... Thanks! |
Posted on: 2012/3/4 22:46
Is that with Canton's dipstick or the stock GM? Is there a chance they are different?
Posted on: 2012/3/4 22:53
rklessdriver | Re: High RPM Oil Pressure Drop, Round IV | ||
The factory dipstick will read low with a Canton and many aftermarket pans because the aftermarket pans run the oil level lower in the sump to get it further away from the rotating assy.
Just make a note of where it reads with 7qts. Glad it's fixed! Will |
Posted on: 2012/3/4 23:05
I know getting to bolts going down the side rails above the oil pan kickout are fun ask me how I know this LOL.
Glad it worked out for you. |
383 4 bolt main (10.5 to 1) Balanced, Flat top , pistons LT-4 Hotcam, C C ultra pro magnum steel 1.6 RRA, Trick Flow Heads Super 23 (195 runners) 62cc , SPL runners, Hi Flow intake base, 24# FIC Bosch 3 Injectors, Chipped, Melrose full headers, 3 way Main |
bogus | Re: High RPM Oil Pressure Drop, Round IV | ||
Excellent news!!!
Posted on: 2012/3/4 23:34
