297 user(s) are online (239 user(s) are browsing Forums)
The ...
ToppThat Nitto ivo or motivo
Des Plaines. IL
30 Posts
my builder has a procharged customer who liked his ivos mine are stock f1s the cost looks good. Any pros and cons would be appreciated.Car lift mods in less then a year has me on a budget.
Posted on: 2012/5/3 4:06
bogus Re: Nitto ivo or motivo
Nitto isn't a bad tire.
Are the F1s the run flats? If so, I would lose those pigs.
Posted on: 2012/5/3 6:56
Durango_Boy Re: Nitto ivo or motivo
I've read a few negative reviews about the Invo tires wearing very quickly. If you look around they are hands down the cheapest tire that big unless you buy used. It's great that they are cheap but what if they only last half as long as a more expensive alternative? Then you're buying tires twice as much and spending the same coin. You get what you pay for and I have seen too many Nitto tires go bald too fast.
Posted on: 2012/5/3 11:47
ToppThat Re: Nitto ivo or motivo
Des Plaines. IL
30 Posts
Thanks for the tips. What im really curious about is traction, im frying my stock tires,but learning alot about high speed corrections. 7000 mi.and even the front runflats are getting thin.If i can expect less durability from ivos ill keep saveing.
Posted on: 2012/5/3 15:51
The runflats are junk... they are not a good tire.
Look at the Michelins... Expensive as hell, but... sticky.
Also check out Yokohama, Bridgestone and Toyo.
Posted on: 2012/5/3 16:30
BillH Re: Nitto ivo or motivo
ToppThat wrote: Thanks for the tips. What im really curious about is traction, im frying my stock tires,but learning alot about high speed corrections.
Can you explain how you are frying them Danny? And the high speed corrections.
Posted on: 2012/5/3 19:26
flyboy Re: Nitto ivo or motivo
Well, the Motivo is an all weather design with a 560 tread wear rating. Kind of a mismatch for a car with 525hp, no?
Do they even come in the size to fit your Z06?
Even the Invo with it's 260 wear number is more of a touring tire.
NT05's or 555R's in back and 555's in front.
I just purchased a set of 555's, 2554517/2854017 for $600 total, mounted and balanced. There are some great deals out there on them. If you burn them up in a year or two, blame it on all that horsepower and get another set.
Posted on: 2012/5/3 19:37
Des Plaines. IL
30 Posts
combination of repressed childhood feelings-suicidal tendencies and great car. Thanks for ivo info,pilots are a favorite but savings can be for future clutch ect.
Posted on: 2012/5/4 0:57
Matatk Re: Nitto ivo or motivo
ToppThat wrote:
im frying my stock tires,.... 7000 mi.and even the front runflats are getting thin.
That was a common complaint with a lot of C6s in the first couple production years. Happened to my cousin. Not sure if the factory changed the tires after that or not.
Posted on: 2012/5/4 11:51
Michelin Pilot A/S have gotten good reviews on other sites. Looks like you'll spend around $14-1500 total.
Posted on: 2012/5/4 11:58
I have the Pilot Sport A/S Plus series on my C3. The sizes aren't as radical so neither are the prices but so far I am very happy. Grip is great, no road noise, supposedly wonderful all weather capability, and I'm hoping for good tread life based on the reviews.
Posted on: 2012/5/4 12:48
All I have heard about the Pilot's is they lose their wet weather traction after about 5k miles... be alert, if wrong, great!
Posted on: 2012/5/4 20:00
Des Plaines. IL
30 Posts
I will miss the lack of remorse i have for the stock f1s
Posted on: 2012/5/8 2:53
