186 user(s) are online (161 user(s) are browsing Forums)
1Fast04Vert 92 LT1 Heater Hose Question
Anyone have a picture of the heater hose routing for the 92 LT1? I know it is a lot different from mine, but someone on another forum is confusing me about how his are routed.
Posted on: 2012/5/3 22:24
bogus Re: 92 LT1 Heater Hose Question
not on me... but I can try...
1. hose leaves upper radiator, hits T and separates to throttle body.
2. coolant passes through throttle body to hose that goes to the heater core.
3. out of the heater core into the surge tank.
4. out of surge tank and back to water pump.
The only differences? Your car does not have the T, it has two ports on the water pump. The throttle body gets its water from somewhere else, I don't remember where off hand.
Posted on: 2012/5/3 22:51
92Polo Re: 92 LT1 Heater Hose Question
91 Posts
Sounds about right.
Posted on: 2012/5/3 22:55
1Fast04Vert Re: 92 LT1 Heater Hose Question
Thanks Andy, that was just what I needed.
Posted on: 2012/5/3 23:32
BillH Re: 92 LT1 Heater Hose Question
Pics:
1. the Tee & hose that goes to the TB
2. TB & W/P connection
3. The TB hose goes to the lower heater core connection, the upper HC connection - a U shaped hose to the surge tank,
the other surge tank hose goes to the WP
4. Note that the TB to HC hose has a restrictor (that GM stupidly calls a valve) that reduces flow to the HC.
jpg  2006-08-28 09-35-32_0002.JPG (0.00 KB)
jpg  2006-08-28 09-36-25_0003.JPG (0.00 KB)
jpg  2006-08-28 09-36-37_0004.JPG (0.00 KB)
jpg  2006-08-28 09-36-51_0005.JPG (0.00 KB)
Posted on: 2012/5/4 0:10
I did away with all of that crap.
I used a 96 water pump and got rid of the T. The ultimate throttle body by pass. Got rid of 5 potential leak points.
Posted on: 2012/5/4 0:32
I would but remember, I don't work on my car, I just drive it.
Posted on: 2012/5/4 1:48
rklessdriver Re: 92 LT1 Heater Hose Question
I did the same thing on my 92... but I used a WP housing off an Impala which actually made routing the heater hoses around the front of the engine a little easier.
Do you still have the valve/restrictor inline?
Posted on: 2012/5/4 17:15
I am pretty sure I do have the restricter... My logic being, this was after the waterpump and perhaps actually has a reason for being there... perhaps to keep the heater core from blowing up?
Posted on: 2012/5/4 17:42
Yep, we had this discussion on the NCRS forum. One of the guys worked in the plant and he said that was why it was there.
There was also some discussion on the pellets GM recommends plugging up that orifice (but not really confirmed).
Posted on: 2012/5/4 21:41
So 92 are plumbed one way, 93-94 another way, and then 95-96 a third way. 3 different ways in 4 yrs = GM engineering at its worst.
Posted on: 2012/5/4 22:51
I figured there had to be a reason it was there.
Thanks
Posted on: 2012/5/4 23:44
Thanks
What's funny is, I was changing heater hoses, saw the restrictor, lookes in the FSM and they called it a valve.
My first thought was WTF? A valve? A Check Valve? in the cooling system???
THEN, I pulled it and looked thru it, thought, a valve? There's no damn springs, poppets, just a hole, did my VALVE self distruct???
Posted on: 2012/5/5 0:21
No... it allows GM to charge more for a "valve" than a "piece of plastic with a hole in it."
Posted on: 2012/5/5 0:24
Posted on: 2012/5/5 0:33
