121 user(s) are online (72 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
istter1 Lower ball joint zirk removal
Bakersfield Ca
2336 Posts
How do you get it out clogged?? lower control arm ball joint
odt zirk.odt Size: 151.55 KB; Hits: 136
jpg  lower zirk.jpg (286.54 KB)
5144_4fbaefaf8866d.jpg 2048X1536 px
jpg  lzirk1.jpg (151.12 KB)
5144_4fbaf27e0d145.jpg 2048X1536 px
odt zirk1.odt Size: 194.36 KB; Hits: 159
jpg  ZSU-594.jpg (16.04 KB)
5144_4fbaf66c0b407.jpg 300X214 px
Posted on: 2012/5/22 1:46
Edited by istter1 on 2012/5/22 2:04:10
Edited by istter1 on 2012/5/22 2:10:43
Edited by istter1 on 2012/5/22 2:11:48
Edited by istter1 on 2012/5/22 2:14:10
Carol Burnett
1Fast04Vert Re: Lower ball joint zirk removal
Unscrew it.
Posted on: 2012/5/22 2:07
Matatk Re: Lower ball joint zirk removal
You just want to remove it? Like Andy said, it just screws in. Use a pair of pliers.
Posted on: 2012/5/22 2:10
istter1 Re: Lower ball joint zirk removal
Bakersfield Ca
2336 Posts
Turned that sucker for 10 minutes just spinns
Any ideas not expensive. It is bone dry.
http://www.autozone.com/autozone/part ... itemIdentifier=23678_0_0_
Posted on: 2012/5/22 2:15
Carol Burnett
You could try holding the top of the ball joint in that slot with a screwdriver. But I'm guessing if it's that dry and just spinning your ball joints are shot. Don't get duralast, get moog. I've also had good luck with raybestos professional on by BIL's F150.
Posted on: 2012/5/22 2:27
Bakersfield Ca
2336 Posts
I figured something may be wrong I was looking at Moog.Don't care if they cost more want them to last.
Spotted this problem while greasing up Caliper pins. bone dry also lol
http://www.oreillyauto.com/site/c/det ... ball+joint+%26+components
Posted on: 2012/5/22 2:33
Carol Burnett
I'll warn you the ball joint replacement on the c4 is a lengthy, involved process. Just so you're prepared.
Also, order from rockauto and use the discount code.
Posted on: 2012/5/22 2:42
Bakersfield Ca
2336 Posts
I thought it would be a pain in the ass. Just another learning experiance on a different vehicle is the right way to look at it. LOL
Forgot where was code listed again
http://www.rockauto.com/catalog/raframecatalog.php
$68 without code
lot cheaper then Orilies low $111
Talk about being stupid
here it is and almost time fore a new one. 5% is better then nothing
http://www.corvetteguruforum.com/modu ... p?topic_id=16707&forum=61
Posted on: 2012/5/22 2:52
Edited by istter1 on 2012/5/22 3:10:13
Edited by istter1 on 2012/5/22 3:15:21
Carol Burnett
flyboy Re: Lower ball joint zirk removal
I've had some clogged zerk fittings open up after heating them with a propane torch.
Posted on: 2012/5/22 3:21
Bakersfield Ca
2336 Posts
I used to do that on farm equipment. May give it a cautious try. I tried using sodering iorn not much heat.
Found my propane torch in garage will try tomorrow.
Before that I will clean up that area and see if there is an inseration point to stop the zirk from spinning and remove it. Screw driver ice pick ??
Posted on: 2012/5/22 3:24
Edited by istter1 on 2012/5/22 3:52:09
Carol Burnett
RickAnthony Re: Lower ball joint zirk removal
ASE Master Certified
Downers Grove, IL
703 Posts
It looks like the grease fitting has sunk in. This usually is a sign that the joint is worn, If you haven't take the load off the joint by placing a stand under the lower control arm, then check for play grab the wheel/tire at the top and bottom. Sometimes they will feel tight but if you lift up or give them some effort you'll feel them move.. greasing a worn joint will make it feel tighter but it's pointless if it's worn and has play it needs to be replaced..
I also agree Moog is at the top of my list, AcDelco and Raybestos are also good choices.
Posted on: 2012/5/22 4:34
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
Bakersfield Ca
2336 Posts
Good advice Rick thanks. My son will be over after work he has the good eyes and we will check it out together.
More then likely we will be replacing that part . The price from Rockauto looks good. We will look at other parts to see what elese is shaking, I have a week or so coming before I start teaching summer school after the holiday.
Posted on: 2012/5/22 5:38
Carol Burnett
Steve - if the one is bad, chances are they are all bad. Figure tie rod ends, too. Expect to pay in the $400+ range for the complete change.
Posted on: 2012/5/22 11:51
Bakersfield Ca
2336 Posts
I am aware that when I bought the 87 making it safe and spending bucks to fix it was going to take time.
Everything I have put in to my 87 has been worth it. I love working on her. You gotta treat them like a high price girlfriend. lol
Posted on: 2012/5/22 12:26
Carol Burnett
Bakersfield Ca
2336 Posts
Learned something new today grease on this type of balljoint will only flow eaisly when the zirk is in alignment with the slot. Still don't know how to remove it.
I took the vett to a local alignment shop they said ball and tie road ends were in decent shape. They aligned it for me last year.
Learn something new every day.
5144_4fbc436148c51.jpg 2048X1536 px
Posted on: 2012/5/23 1:58
Carol Burnett
Good tip. I've never heard that before. I don't understand why, though, since it's just a hole on the other end?
Posted on: 2012/5/23 2:29
BillH Re: Lower ball joint zirk removal
Yea, doesn't make sense.
Posted on: 2012/5/23 3:08
Bakersfield Ca
2336 Posts
I would guess someone that won't work on your car if nothing is wrong is honest or has been busted by Ca DMV. I hope he is just honest. He didn't charge a anything. Greased the zirk and all. Lol
I have never seen a slot like that before. I was looking forward to replacing that stuff the week before summer school starts.
Had all the parts I would need from Rock auto written down so I could order them.
Posted on: 2012/5/23 3:52
Carol Burnett
I wonder if it was screwed in too far and making contact with something and if he backed it out it was free to flow. Still strange.
Posted on: 2012/5/23 12:09
Bakersfield Ca
2336 Posts
All I know for sure is he fixed it. I didn't get to watch him work. I do know that their hi pressure grease gun works better then my harbor freight.He was a talker.
When I got it home I used my grease gun on it and it worked fine.
Posted on: 2012/5/23 12:18
Carol Burnett
They won't go in that far and the zerk's pipe thread so it can't be screwed in that tight.
And, the groove - the greese groove is in the bearing (housing) not the ball.
"I do know that their hi pressure grease gun works better then my harbor freight"
This wouldn't supprise me, may be correct.
Posted on: 2012/5/23 14:22
Bakersfield Ca
2336 Posts
When we had the thread on grease guns what was the consenses on the best quality?
Posted on: 2012/5/23 18:29
Carol Burnett
If he used a good one it probably freed up the gunk which then allowed your cheap one to work.
I bought a lincoln, very happy with it so far.
Posted on: 2012/5/23 23:09
Bakersfield Ca
2336 Posts
Cheap one
LOL
Posted on: 2012/5/23 23:37
Carol Burnett
Cheap one
LOL
I bought an autozone POS (oem brand?) and another cheap one before I got smart. Those both broke or just wouldn't work. I think I spent $15-20 for each cheap one and about $35 for the good one. Do the math there....
Posted on: 2012/5/24 3:05
Bakersfield Ca
2336 Posts
Matatk wrote:
Cheap one
LOL
I agree you get what you pay for.
Posted on: 2012/5/24 3:09
Carol Burnett
Bakersfield Ca
2336 Posts
istter1 wrote:
Matatk wrote:
Cheap one
LOL
Which model lincoln
there are a lot of models lol
http://www.ebay.com/sch/i.html?_nkw=l ... grease+gun&_ipg=100&rt=nc
Posted on: 2012/5/25 0:00
Carol Burnett
I think Matt got this one.
It's good because, if you have a zerk that tha hose keeps popping of of, this gun is one handed because og the pistol grip.
http://www.ebay.com/itm/LINCOLN-1133- ... ain_0&hash=item484434f4c7
Posted on: 2012/5/25 0:14
Posted on: 2012/5/25 0:20
Same one as Bill posted. So I guess it was a couple bucks cheaper than $35, maybe $29 shipped or along those lines.
Posted on: 2012/5/25 0:22
bogus Re: Lower ball joint zirk removal
Ball joints... gotta be getting close for mine again...
Same with the front wheel bearings.
I do need tie rod ends this time around, tho. those have been on for 182k miles... so, time to stop flirting with disaster.
Good job on the ball joint, Steve. I would replace all four, tho. If they were that dry, I am shocked they didn't break apart on you.
Posted on: 2012/5/25 1:02
Bakersfield Ca
2336 Posts
I had planned on picking up those parts and if a problem occurs or I plan a trip I will install what ever is needed.
Like we all say it 25+ years old. Parts right now are cheaper and these can sit on the shelf for a while without much damage.
Posted on: 2012/5/25 3:30
Carol Burnett
