225 user(s) are online (194 user(s) are browsing Forums)
Assembly Line Diagnostic Link
istter1 Fuel pump performance vs oem
Bakersfield Ca
2336 Posts
I remember a while back a while there was a thread on parts going bad and I am in the market for a new fuel pump for the 87. I know some make noise and some have warrenty and others don't. I also know that the fuel presure is controlled else where by a fuel pressure Module.
What is the best bang for the bucks. I don't want to replace one every two years.
I don't mind spending more for quality and longer life products.
Who can you trust on ebay vs autoparts stores?
I would imagian there are some fony china made replica parts out there.
http://www.autozone.com/autozone/part ... tifier=708561_90318_9312_
http://www.autozone.com/autozone/part ... 4ECFFC4924.diyprod1-b2c11
http://www.ebay.com/sch/i.html?_nkw=8 ... =87+vett+fuel+pump&_rdc=1
Posted on: 2012/5/12 15:36
Edited by istter1 on 2012/5/12 16:02:11
Carol Burnett
383tpimachine Re: Fuel pump performance vs oem
Corpus Christi
976 Posts
I searched but cant find my tuner that sold me my fuel pump but it was a GXXX and a walbro IIRC and has been fine for 3+ years. No issues at all.
Believe it was a 340 model and blew a fuse. Fixed that issue.
Posted on: 2012/5/12 16:12
1970 El Camino-Awaiting LSX
istter1 Re: Fuel pump performance vs oem
Bakersfield Ca
2336 Posts
is this a good price. this place has there version they claim is equal.
http://www.ebay.com/itm/Walbro-400LPH ... p=mtr&hash=item415dfab6b0
http://www.ebay.com/itm/340LPH-High-P ... p=mtr&hash=item4ab6082ee2
Posted on: 2012/5/12 16:57
Carol Burnett
Ultraman Re: Fuel pump performance vs oem
14743 Posts
I think this is what you are looking for.....
I used the kit designed for my 90 and it was all good... Walbro pump....190 gph....all you need.
http://www.racetronix.biz/customkititems.asp?kc=FPA%2D011&eq=
Posted on: 2012/5/12 17:19
Corpus Christi
976 Posts
The 340 lph is the unit I have but like Ultraman posted go through Racetronix and ask if you need to upgrade the wiring as 85 may be different from your year.
Racetronix are awesome with great customer service
Posted on: 2012/5/12 17:27
Bakersfield Ca
2336 Posts
Hell of a deal. With parts I would have to order seperatly.
As for the wireing
"In-tank Wiring - Racetronix Exclusive!
In-tank wiring is quickly becoming a major problem due to the age of the C4's. Many terminals are heavily corroded or rusting off.
The generic in-tank wiring adapters supplied with other installation kits rely on the questionable factory wiring and adds another connection to the equation. This translates to more resistance / voltage loss and an extra potential failure point.
Racetronix in-house harness manufacturing facility has produced a one-piece replacement for the in-tank pump wiring. Racetronix replacement in-tank wiring plugs directly into the new pump and into the factory bulkhead connector thereby eliminating all the factory pump wiring and the need for in-line plug adapters. The Racetronix harness is made with heavier 14 gauge Teflon wire vs. the factory's 16 gauge wire. Teflon is the most resistant to gas and solvents. All connections are assembled using our computerized crimp-quality monitoring system and then circuit checked for the utmost in reliability. There are no wires to cut, crimp or splice. All connections are Plug & Play. "
Thanks
Posted on: 2012/5/12 18:07
Carol Burnett
Bakersfield Ca
2336 Posts
Just ordered one
Thanks
Posted on: 2012/5/12 18:20
Carol Burnett
14743 Posts
Atta boy! Matt has a great how to change out the fuel pump post in Guru C4 tech I believe....with pics!!! Very nice!
Posted on: 2012/5/12 18:35
Bakersfield Ca
2336 Posts
Looks easy but love pictures. Very visual.
when golf is over I will start looking for Matt's how to.
Posted on: 2012/5/12 19:49
Carol Burnett
Bakersfield Ca
2336 Posts
Found link awsome. Nice write up Matt.
http://www.corvetteguruforum.com/modu ... id=129791#forumpost129791
Posted on: 2012/5/12 21:20
Carol Burnett
Matatk Re: Fuel pump performance vs oem
Thanks, just saw this post. I was going to recommend racetronix. Their pump kit was cheaper than getting a GM setup, too.
Posted on: 2012/5/13 15:17
Bakersfield Ca
2336 Posts
The pump is on the way from Canada. I am signing up for their tech Forun.
Suddenly what Andy said not to post from other sites was there to read. Hear it is. LOL
THE FOLLOWING RULES WILL BE STRICTLY ENFORCED TO ENSURE OUR FORUM REMAINS AN ORDERLY, VALUABLE ASSET AND PLEASURABLE EXPERIENCE FOR OUR CUSTOMERS:
This is not a public forum and all posts are subject to moderation.
Discussion should be related to the technical support of Racetronix product only.
Information on this forum is not to be copied and re-posted elsewhere including on other public forums.
Correspondence with Racetronix, other customers or Racetronix dealers is not to be redistributed or published elsewhere without express permission from the parties involved.
All documents posted in the Racetronix forum are watermarked for tractability and may not be reproduced or redistributed.
Spamming, aggressive or lewd behavior will not be tolerated.
Short and to the point.
Posted on: 2012/5/15 0:13
Carol Burnett
Bakersfield Ca
2336 Posts
The pump showed up Monday and now that the zirk is fixed I hope to change this out and install the door weather strips.
Thanks Marcus for the tip on the pump. Great price quick delivery
didn't realize the Walbro gss242m is equivalent to the Holley p/n gss344m
Hope to have that done over the 3 day weekend. Would rather go to the beach.
Posted on: 2012/5/23 4:07
Carol Burnett
The fuel pump change is an hour job. You can knock that out in three days
Posted on: 2012/5/23 12:05
NC Kid Re: Fuel pump performance vs oem
North Carolina
1671 Posts
Racetronix has good parts but getting a bigger fuel pump wont help give you performance. If nothing else, get it for the quality workmanship/customer service. Might be helpful in the future if you do a bigger motor. Save time/money.
Posted on: 2012/5/23 21:18
Bakersfield Ca
2336 Posts
Car started running like fule starved the last few days. Ran bad on the way home. Just finished installing the pump. Lol what a difference in performance. For two years that I had this car I didn't know it would change for the best again. Marcus and all that recomended this pump Thanks.
In one of the pictures you will see the filter black as hell and falling apart. You will see the wire adapter for this pump it is I think telphon coated or something to make it last longer in the exposure to fule. Ths SS bolts were a nice change and the gasket and all were perfect.
jpg  fp1.jpg (293.46 KB)
5144_4fc04c2142f8c.jpg 2048X1536 px
jpg  fp2.jpg (296.64 KB)
5144_4fc04c3310837.jpg 2048X1536 px
jpg  fp3.jpg (332.41 KB)
5144_4fc04c4405c39.jpg 2048X1536 px
jpg  fp4.jpg (368.53 KB)
5144_4fc04c58d6144.jpg 2048X1536 px
jpg  fp5.jpg (287.92 KB)
5144_4fc04c6aa955c.jpg 2048X1536 px
jpg  fp6.jpg (310.42 KB)
5144_4fc04c7d91791.jpg 2048X1536 px
jpg  fp7.jpg (232.70 KB)
5144_4fc04c8de1ba8.jpg 2048X1536 px
jpg  fp8.jpg (359.39 KB)
5144_4fc04ca0ee18a.jpg 2048X1536 px
jpg  fp10.jpg (373.79 KB)
5144_4fc04cc0545cb.jpg 2048X1536 px
jpg  fp11.jpg (187.39 KB)
5144_4fc04cd6e0a9f.jpg 2048X1536 px
Posted on: 2012/5/26 3:24
Carol Burnett
That old sock was pretty rough! Glad the new pump has put some pep back into the old girl.
Posted on: 2012/5/26 11:16
14743 Posts
Well done Steve! I wish the C5's were as easy to get to and change out.........
Posted on: 2012/5/26 13:14
