bogus | POP! That was unexpected... | ||
I was negociating slow traffic and trying to beat out a green turning to yellow, so I floored it.
I was in 4th (manual) and the car sped up ok (I still say it's soft, I think 183k miles have caught up with something... valve seals, cam lobes... I donno which). As I went through the intersection, I let off the gas and it backfired, then stuck at 2500 RPM for a moment until I prodded the throttle. Backfires - the POP! in the title are timing related. I am about sure as I can be that my intermitten failures are caused by a crap dynaspark. No codes... but I will confirm. For the newbies, 1992 LT1/MN6, 183k miles, Dynaspark with LTCC (uses 8 GM LS2 coils for high voltage). Taylor wires, NGK plus (10k miles each), new NGK O2 sensors. New Racetronix fuel pump and new WIX fuel fiter. Thoughts? |
Posted on: 2012/7/11 15:54
Durango_Boy | Re: POP! That was unexpected... | ||
Man even the good after market Opti offerings have issues.
GM should have tossed that idea out LONG before it made it into production. I mean seriously, is there an advantage to Opti over rear distributor? |
Posted on: 2012/7/11 16:04
bogus | Re: POP! That was unexpected... | ||
technically, it is the most precice ever made, and the optical pickup is actually the good part, OEM... it's made by Mitsubishi and is known to last 250k miles in a conventional distributor.
I think that the dynaspark guy can't or isn't getting Mitsu sensors. To think, GM had lost spark in 1992... |
Posted on: 2012/7/11 16:31
Churchkey | Re: POP! That was unexpected... | ||
Did it backfire out the exhaust or sneeze through the intake?
Posted on: 2012/7/11 16:33
BillH | Re: POP! That was unexpected... | ||
Put an MSD on.
Posted on: 2012/7/11 16:51
sneezed through the intake - good description, churchkey!
I have an entire 96 LT1 waiting to go in, I ain't buying jack for this motor. As soon as it is out, I am doing a leak down on it. |
Posted on: 2012/7/11 17:05
SpectatorRacing | Re: POP! That was unexpected... | ||
My MSD failed as fast as my OEM. They're hit or miss. Put on the cheapest known good part you can find. |
Posted on: 2012/7/11 17:34
aka Scaryfast |
I thought you had an LS7 to put in? |
Posted on: 2012/7/11 17:35
aka Scaryfast |
Hell no. I have a brainstorming session thread, no engine... the LT1 is a stop gap until I can get enough parts to make a decision.
Posted on: 2012/7/11 18:09
BrianCunningham | Re: POP! That was unexpected... | ||
I'd find out why the throttle stuck 1st
Was it the IAC? |
Posted on: 2012/7/11 19:21
it was odd about the throttle. Maybe I imagined it was stuck, maybe it was. I have never had that happen, so perhaps the engine was holding revs in accordance to the gear it was in? I didn't try neutral or anything like that.
The IAC is a rather new part, GM at that. I have not had any issue with the car holding idle. |
Posted on: 2012/7/11 19:45
That's why the raceshops put regular distributors in anything that has constant high revs. The GM is junky compared to the MSD. |
Posted on: 2012/7/11 21:58
Probably a timing thing. Streched timing chain + according to conversation on CF the opti can be off a number of degrees internally. Being a standard shift the engine will go from load to no load instantly, cam & ignition timing will change instantly if the timing chain has stretched. It will probably happen again.
Since it sneezed (old biker & track racer term) suggest checking all vacuum hoses & caps on the intake as they tend to blow off when there is an explosion in the intake manifold. GL |
Posted on: 2012/7/12 2:53
I will check the vacuum lines - again, great observation!
Stretched chain? Likely... the engine has 183k miles on it! I am really going to need to get my act together and get this motor out. It's about done. |
Posted on: 2012/7/12 14:57
RickAnthony | Re: POP! That was unexpected... | ||
ASE Master Certified
Speaking of Opti's...
Anyone use one of these? http://www.ebay.com/itm/1995-1996-199 ... sh=item3a6bad337d&vxp=mtr I'm sure this is a made in china type.... I bought one for our nova, to upgrade it to HEI, most the regular manufacturers make their economy distributors over seas anyway so I figured I'd try it.. works gread and it was only like $40... though with one of these there is quite a bit of labor envolved... but if your doing it yourself you may want to try one out and see how it works, I'm curious.. afterall it has a warranty... (which doesn't cover your time obviously.. ) -=Rick |
Posted on: 2012/7/13 5:59
Interesting...
Posted on: 2012/7/13 7:01
