251 user(s) are online (198 user(s) are browsing Forums)
Dads90 Simple timing question
Pearland, Tx
318 Posts
Is retarding the timing moving it closer to Zero ? Or is it the opposite ?
Posted on: 2008/2/16 22:16
Notorious RE:Simple timing question
Advanced is moving beyond zero and retarding timing is moving it back toward zero, yes.
Posted on: 2008/2/16 22:18
Dads90 RE:Simple timing question
Pearland, Tx
318 Posts
Thanks Notorius, I've put in a chip and it says to retard timing if a knock becomes present, of course it does. I didn't want get the present setting screwed before I start.
Posted on: 2008/2/16 22:30
RRTvette RE:Simple timing question
Bogalusa, LA
50 Posts
Posted on: 2008/2/17 2:57
MK 82 Re: Simple timing question
Palm Beach Gardens, FL
439 Posts
Depends on which side you start off on!
Posted on: 2008/2/17 3:01
96 CE Roadster LT4
CasetheCorvetteman Re: Simple timing question
My thoughts too as soon as i read it!!
Posted on: 2008/2/17 8:07
MK 82 RE:Simple timing question
439 Posts
Great minds think alike!
Posted on: 2008/2/17 14:47
96 CE Roadster LT4
fnsblum RE:Simple timing question
Nothern Utah
32 Posts
I never owned a car/truck that fired after top dead center. All were several degrees before TDC. If you are retarding the timing you are removing some of the degrees before TDC. Later! Frank
Posted on: 2008/2/17 20:46
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
Pearland, Tx
318 Posts
Thanks guys , its done. I knew the setting was at 6 * BTDC. I have adjusted it many times, but never knew the terminology of retard and advance. I feel like a retard sometimes when I go thru so much with this car and it still acts up.
Posted on: 2008/2/18 2:25
