309 user(s) are online (237 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
PLRX Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
SoCal
212 Posts
I started this project with the 12V outlet and it evolved into many other things I have
been letting them slide.
The goal here is to replace the Bose (what a great "radio") with Corvette Central's Pioneer
direct plug like the one I already have in The Ghost. To remove the Bose is easy, but the
new radio comes with multiple connection which travel from the console to the receiver in
the jack box. The cables must be placed under all the plastic and carpet between the
seats and cargo area.
Crud from the rails
The infamous hidden screw.
Remove side skirts
Before the center console is completely remove the power seat controls must be
disconnected. The cables run from the control thru the carpet and underneath the seats.
Lazy GM worker did not installed the power cables properly :D
Realized there is another/extra set of power cables available.
Power Seat Connectors
Cassettes are long gone:seasix:
View from the rear
The emergency handle was full of drirt, junk, hairs and rust.
Did the best I could
Back on the sill
A quick carpet cleanup
Realized it was a great time to finally fix the high-beam lever actuator. It broke back in
2007. Remove the 4-bolts from the rear and remove the airbag.
The horn buttons worked, but they were cracked. Luckily, I bought the horn set for
The Ghost. His left horn buttong has been down for ever, and now Betty Boop will use it.
Remove wheel
Remove clip
The infamous C-Clip
I got help from John[I] "Gear Jammer"[/I]:seasix:
To replace that POS plastic lever actuator was not easy. Had to disconnect all wires from
underneath, loose the steering column and pull the cables for the air-bag plate, horn
connector, and signal lights connector would come out.
This is how it looked once I realized what to order and fixed the high-beam rod. It was out of
place. I have no idea how that thing got inside the steering skeleton.
This is what actually broke. Another excellent piece of C4 plastic which pushes a long steel rod into a switch.
To install it it had to be packed with grease for it not to move and after five attempts it worked out.
You may think it could be slide, but there is a tab that goes into the actuator from the side cover.
I got it all back, had to crawl upside down and reconnect all wires, re-insert the plastic
slide, and reconnect the air-bag yellow cable.
Being a midget has it's advantages.
Posted on: 2012/10/12 1:13
PLRX Re: Betty Boop's 1995
SoCal
212 Posts
The radio came in on Thursday. This replaces the receiver.
A regular antenna is needed for the new radio.
An adapter is needed to connect the Vette's OEM antenna cable to the new cable.
Disconnected cable from receiver.
Connected adapter.
All cables or connections go thru and under the middle carpet.
Don't let it scare you.
Unplug all old connections from the receiver, and make new connections
New radios rear. See that small hole?
need old bose's rear guide.
This needs to be used on the new radio
The radio fascia needs to be trimmed. I over trimmed it, it may not looks bad, but
I'm too picky, and ordered a new one today.
View
Re-installed the rear compartment tray, and velcro the carpet back into place.
Reinstalled the center console frame, power seats controller, connections, and connected
a tri 12V outlet to the auxiliary power cable.
Posted on: 2012/10/12 1:14
SoCal
212 Posts
I considered new seats, drank the kool-aid, and right before I was about to place the
order. I wondered how black seats would look with the light gray interiors. Betty Boop
had black floor mats, and they looked alright. The light gray seats wee old, but in good
condition. The Ghost's seats are black, and they look great! Got them ordered last
week, and arrived yesterday.
I started the installation while South Park was in the air. It was great I was LMAO.
Al Knoch makes great seat, but for $1,000 [B]I expec[/B]t a flaw-free product. The anchors are f*ucking
backwards on both cushions.
I think the black seats with light gray looks awesome. I also bought a second weather tech for Betty Boop's
cargo space.
Posted on: 2012/10/12 1:18
pianoguy Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
Manly effort, Pete - looks great!
Posted on: 2012/10/12 1:44
TommyT-Bone Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
33766 Posts
Good pics and write up Pete.
Posted on: 2012/10/12 2:51
bogus Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
Pete! Great to see you back!!
the project looks AWESOME!!!
Posted on: 2012/10/13 23:33
j3studio Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
C4s: not built to be maintained.
Great pictures, good job!
Posted on: 2012/10/13 23:45
Matatk Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
Great pics! And good job on the fixes!
Posted on: 2012/10/14 2:21
flyboy Re: Betty Boop's 1995 Interios, Seats, Horn, High Beam, and more
Lot's of work there. Good thing it's not your DD.
C4, 21st century Hot Rod.
Posted on: 2012/10/14 20:25
