163 user(s) are online (111 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
« 1 2 3 (4)
istter1 Re: A & D ENGINES
Bakersfield Ca
2336 Posts
istter1 wrote:
we got lucky when we primed the pump we foung the rear main seal that was still in the package was rotten and leaked. Fixed that and glad we hadn't started the engine for the breakin which I hope to do this weekend.
Well I guess Dave isn't reading this anymore I fibed about the oil seal my son installed it wrong
Posted on: 2012/11/16 2:57
Carol Burnett
EngineDoctor Re: A & D ENGINES
La Habra Ca.
791 Posts
Haha, sry Steve, havent been online much
Nice to see it coming together !
Posted on: 2012/11/16 20:11
Bakersfield Ca
2336 Posts
Hope busness is picking up Dave for you.
Posted on: 2012/11/17 2:04
Carol Burnett
Bakersfield Ca
2336 Posts
Well Dave we fired her up and broke the cam in. We will be fixing a few other little things and hope to have it out of the shop and on the road again..
Thanks for all of your hard work.
Posted on: 2012/11/30 1:51
Carol Burnett
La Habra Ca.
791 Posts
You are welcome Steve, and many thanks to you Sir !
Happy to see that you are gett'in her done ;)
She should be a blast to drive .
Posted on: 2012/11/30 21:45
bogus Re: A & D ENGINES
20861 Posts
Can't wait for the driving report!!!
Posted on: 2012/12/2 19:10
Bakersfield Ca
2336 Posts
Well I was out shooting my P98 when John took her out for a test drive. Stalled a couple times but that is what I brought it in for. Guess it is the part the computer talks to has 4 pins plug in that is causing it to stall only when you are driving and when comeing to a stop. Was the reason I was bring it in. John will fix that.
Big problem is the one piece rear main seal leaks at about 3000 rpms. Not at an idle. We replaced the seal that my son installed. John is going to pull the transmission and see that the one piece is conected correctly. It leaks very little. I don't want it to leak at all.
John test drove it and he found out what I had told him about this transmission. Can spin on a dime in low gears and at 75 miles an hour less than 1700 rpm. Awsome gas millege. Average about 27 on freeway
Dam new GMC truck only got 15.6 mpg on way to beach sat.
Posted on: 2012/12/3 4:04
Carol Burnett
La Habra Ca.
791 Posts
Hopefully that r/m seal just needs to be run a bit to seal properly.. You never know , if it was installed properly it should not leak though. 27mpg WOW! ;)
Posted on: 2012/12/3 4:14
Bakersfield Ca
2336 Posts
The orginal window sticker says 24
14-18 cit 20-28 hwy
We talked about driving it to see if it seals but haven't ever had to do before. I will talk to john who is sick of working on vet. He suggested I try that too. I want it back too.
Posted on: 2012/12/3 4:49
Carol Burnett
Bakersfield Ca
2336 Posts
14-18 cit 20-28 hwy
I have vet at home love the sound of it. Everything works great. The throwout bearing works great everything shifts great. Lots of power and the bad part is mu uncle died and this friday will be a big Catholic funeral (x policemen) will have police escorte all that stuff. I won't be able to take a run to see about gas millege on the road for a weel or so.
Thanks Dave
Posted on: 2012/12/4 5:15
Carol Burnett
La Habra Ca.
791 Posts
istter1 wrote:
14-18 cit 20-28 hwy
Thanks Dave
Steve, I am very sorry bout your uncle.
Also I am very happy that you are pleased with you stroker, and once again, thank you for letting me be of service to you !! Happy Strok'in to you Stevo ;)
Posted on: 2012/12/4 21:01
La Habra Ca.
791 Posts
EngineDoctor wrote:
istter1 wrote:
14-18 cit 20-28 hwy
Thanks Dave
Also, I am very happy that you are pleased with your stroker, and once again, thank you for letting me be of service to you !! Happy Strok'in to you Stevo ;)
Posted on: 2012/12/5 3:49
La Habra Ca.
791 Posts
New project, 57' Hemi ! I'll start on the heads first, Then deal with the lower end. Customer want's to stroke-it increase stroke .
bmp  57' hemi.bmp (900.05 KB)
7794_50c024ac82d32.bmp 640X480 px
Posted on: 2012/12/6 4:53
20861 Posts
cool... how much can you stroke those old 392s? I assume someone makes a crank for it...
Posted on: 2012/12/8 2:34
Matatk Re: A & D ENGINES
22812 Posts
Sorry to hear about your uncle, Steve. But glad the engine/trans are working well.
Look forward to seeing the next hemi project in photos.
Posted on: 2012/12/8 19:41
La Habra Ca.
791 Posts
Andy, the existing crank will be offset ground to
increase stroke,then we will need pistons with a different wrist pin location to increase stroke aswell.
Posted on: 2012/12/10 21:58
Bakersfield Ca
2336 Posts
Well Dave my son went for his first drive in the vet and he mentioned wtf and omg. He realizes what kind of work you did on the engine.
Cool
Posted on: 2012/12/10 22:24
Carol Burnett
La Habra Ca.
791 Posts
Cool
Hahaha, cool ! Thanks guys Say hi to your son 4 me Steve.
Posted on: 2012/12/10 22:43
La Habra Ca.
791 Posts
May as well take a vacation.
WORK is DEAD this month
Posted on: 2012/12/19 22:07
pianoguy Re: A & D ENGINES
I'd send you my Vette to work on if you'd move to MN ;-)
Posted on: 2012/12/19 22:25
La Habra Ca.
791 Posts
Thanks, Piano Guy ! Time to clean & prep machines for next year I guess 34-=63=-25536
Posted on: 2012/12/19 22:39
Bakersfield Ca
2336 Posts
Sorry I can't send you another one right now. My engine is great. Trying to work out electrical problems that are making the 383 run wrong. Many things to check.
Could be results of the fire still. Fan main stopped working Fan works fine replaced the relay and lamo wires melt. Like fan is drawing too many amps. Idle problem. may be dist??
Posted on: 2012/12/20 1:12
Carol Burnett
La Habra Ca.
791 Posts
December is always this way at shop
And yes electrical problems are a hassle.!!
Posted on: 2012/12/20 3:27
La Habra Ca.
791 Posts
Machining away at the cylinder head station.
Finishing the seat work, then surface decks.
Posted on: 2013/1/24 2:09
La Habra Ca.
791 Posts
Cutting the seats at 4 angles, interference grind, then lapping valves to seats.
bmp  ah1.bmp (900.05 KB)
7794_51009a233e09b.bmp 640X480 px
Posted on: 2013/1/24 2:19
La Habra Ca.
791 Posts
The heads assembled & vac tested, now to set ring gaps in cylinder bores , then final engine assembly.
bmp  ah10.bmp (900.05 KB)
7794_5101f296c9aa5.bmp 640X480 px
Posted on: 2013/1/25 2:49
La Habra Ca.
791 Posts
Ring end gaps are set.
bmp  sb10.bmp (900.05 KB)
7794_5101f3db0c843.bmp 640X480 px
Posted on: 2013/1/25 2:54
22812 Posts
I want to come work in your shop for a day. You wouldn't even have to pay me
Posted on: 2013/1/25 2:58
La Habra Ca.
791 Posts
Haha, You have an open invitation Matt!, ANYTIME ;)
bmp  yota.bmp (900.05 KB)
7794_51021867c94e8.bmp 480X640 px
Posted on: 2013/1/25 5:30
La Habra Ca.
791 Posts
After owning Linda for 28 years, she drove off into the sunset, under her own steam, and on her way to Switzerland
Farewell Linda , It was fun to own you !
bmp  lk.bmp (900.05 KB)
7794_513d2122d0b52.bmp 640X480 px
Posted on: 2013/3/11 0:12
22812 Posts
Congrats on the sale...I'm sure if the new owner is willing to ship it overseas it will be well cared for!
Posted on: 2013/3/11 2:51
Bakersfield Ca
2336 Posts
Dave motor is as great as you told me.
Can't say thanks enough
Posted on: 2013/5/21 4:54
Carol Burnett
La Habra Ca.
791 Posts
Glad it worked out for you Steve
Posted on: 2013/5/21 18:02
La Habra Ca.
791 Posts
Hello Guru friends!
I am trying to revive my Face book page , and would like your support.. Just go to "A&D Engines" and click like
Feel free to comment etc on my page, and I thank you for your support Guru's!
Posted on: 2013/8/13 3:53
22812 Posts
Done! Now let's see some engine porn!
Posted on: 2013/8/13 22:27
La Habra Ca.
791 Posts
Haha. Thanks Matt !!
Posted on: 2013/8/13 22:38
La Habra Ca.
791 Posts
Thanks Andy Bogus & Matthew R. liking my page !
Posted on: 2013/8/14 21:27
La Habra Ca.
791 Posts
Working on pictures
Posted on: 2013/8/15 4:31
Bakersfield Ca
2336 Posts
Dave got 5000 miles on the 383 stroker and it is costing me tires. Have nothing but praise for the engine you built for me. Need any recomendations tell them to call me.
Posted on: 2013/8/15 18:17
Carol Burnett
La Habra Ca.
791 Posts
Hi Steve, great to hear from you & thank you for
the praise ! ;) !!
Please go to my facebook page A&D Engines and click like
and feel free to comment there on the engine I built for you, and thank you again for your business & support. I do have a picture of your car on there!
Unfortunately only a couple of Guru's have done so
Posted on: 2013/8/15 19:38
Calm Re: A & D ENGINES
Vancouver, Canada
608 Posts
I 'liked'.
But only because I anticipate much more machine work porn.
Posted on: 2013/8/15 20:54
La Habra Ca.
791 Posts
Calm wrote:
I 'liked'.
Appreciate it Calm
I'll try and get some sexy machine work porn out there !
Posted on: 2013/8/15 21:04
Bakersfield Ca
2336 Posts
You need more views on Face book
jpg  383in.jpg (103.81 KB)
5144_522013ed9aa46.jpg 612X816 px
jpg  20121031_163729.jpg (81.33 KB)
5144_52201488c0742.jpg 612X816 px
Posted on: 2013/8/30 3:42
Carol Burnett
La Habra Ca.
791 Posts
Yes I know! The page has only been up a few weeks, thanks for liking & commenting on page Steve,and for allowing me to use your pics too.
Posted on: 2013/8/30 19:02
« 1 2 3 (4)
