188 user(s) are online (125 user(s) are browsing Forums)
BillH Slow Power Door Locks
I did some maintenance today, the pass side door lock was really slow and I didn't like that, probably hard on the solenoid.
Outside of the usual PIA of pulling the panels (I keep bags of those white inserts in the shop), it was a quick fix.
As, I've said before, the problem is usually in the latch mechanism, sticky lock pawl from the old white lube.
Cleaning was super easy, jam a rag inside the door under the latch, hit the levers with brake clean and the latch leavers from the outside of the door.
Sprayed all the parts with PB Dry Graphite.
Took about an hour or so.
Huge difference.
Posted on: 2013/3/11 20:38
joeld Re: Slow Power Door Locks
That's what I had planned to use last week when the door panels were off! Had a senior moment and forgot.
Posted on: 2013/3/11 22:08
TommyT-Bone Re: Slow Power Door Locks
33807 Posts
I'll have to put that on my list.
Posted on: 2013/3/12 0:08
BillH Re: Slow Power Door Locks
Get a supply of the white inserts for the door panel screws.
They can break just by pulling the screw.
Suggest 6-7 per door.
Posted on: 2013/3/12 0:25
Posted on: 2013/3/12 4:17
joeld wrote:
Is this what you used?
http://www.blastercorporation.com/Graphite-Dry-Lube.html
Yea, Joel.
I've been using dry graphite on certain things for a very long time, always have it in the shop.
Saw this at HomeD next to the PB Blaster.
It goes on wet then drys----you have to be real careful when spraying to keep it off any surface you want to keep clean and you don't want to get it on your hands.
But it sure is good stuff.
I have white lithium spray grease too, like GM uses but figured it would just gum up down the road.
Posted on: 2013/3/12 14:38
Again, get some of these, $3.00 for a 4 pack
And the local autoparts stores don't have the correct ones.
jpg  plastic anchors.jpg (0.00 KB)
Posted on: 2013/3/12 14:42
Matatk Re: Slow Power Door Locks
22810 Posts
I have the graphite in the little plastic squeeze bottle...it gets everywhere when you squeeze it. PIA. Looks like the one Bill has works better. But he's right, once it's on something (like carpet, door panel, etc) it's difficult to get out.
Posted on: 2013/3/12 16:10
Well, it's a spray with a tube like WD, you have to be really careful.
Posted on: 2013/3/12 17:31
kenvetted Re: Slow Power Door Locks
santa monica
13 Posts
My power door lock on my 91 don't work, I'd like to start by finding the fuse that is supposed to be in the pannel directly infront of the passenger seat... but I can't fund it up there.... ANYone.... please help.
Posted on: 2013/4/4 7:37
