ttpfi | Parts help | ||
I have been chasing an oil leak in my 1996 LT4. Tracer is showing its the oil filter housing. I put new gaskets on but its still leaking and appears to be the housing its self. Where can I locate a oil filter housing. GM parts is showing not available anymore.??
Posted on: 2013/5/15 21:48
rklessdriver | Re: Parts help | ||
Call one of the Corvette parts recyclers like Vette to Vette.
Will |
Posted on: 2013/5/15 22:13
1Fast04Vert | Re: Parts help | ||
vette2vette.com might have a used one. That is a very unusual part to leak. Usually it is the rear of the intake manifold sealer, which in turn runs down by the oil filter.
Posted on: 2013/5/15 22:14
bogus | Re: Parts help | ||
Exactly my thinking. It would be odd if the housing is leaking. It would have to be scarred or something bad to leak past the gasket and o-ring. |
Posted on: 2013/5/15 22:21
pianoguy | Re: Parts help | ||
If it turns out to be coming from the intake, check the torque on the bolts. Mine were a bit loose on both ends, causing leaks.
Posted on: 2013/5/15 22:52
33 ft lbs if I remember correctly. Another FYI - Advanced, Autozone, and NAPA here had the part wrong on the LT4. They get kept sending me LT1 gaskets and insisting that they were correct for the LT4. Wrong! LT4 is different. Also at idle I could not see my leak, but once the engine was revved up it was very visible. |
Posted on: 2013/5/15 23:10
ttpfi | Re: Parts help | ||
I am going to check the intake today but I will reorder the gasket and make sure its for the LT4. Trying to get the engine stuff completed before I take on the suspension.
Posted on: 2013/5/16 11:30
I was referring to the intake gasket, NOT the oil filter. |
Posted on: 2013/5/16 11:44
