113 user(s) are online (51 user(s) are browsing Forums)
Frank Steering box
188 Posts
Need help in identifying this steering gear box. Its currently on a 1955 cj3b willy's jeep but a lot of parts came from a 1962 impala. Any ideas? Thanks.
jpg  steering 015.JPG (799.43 KB)
6042_519eb61d341f2.jpg 2592X1944 px
Posted on: 2013/5/24 0:36
BillH Re: Steering box
Yea, Frank, that's a GM Saginaw, millions of them produced.
Probably used on some cars/trucks by all the U.S. manufacturers for a very long time.
You need the casting number and size of the splines to correctly identify it but that will probably show that it was used on a lot of vehicles.
Get the number and type "Saginaw" with that number into Google.
BTW, it looks a lot like the one I have on a shelf in my shop (67 C2).
Posted on: 2013/5/24 1:51
Frank Re: Steering box
188 Posts
Thanks Bill. Great information. I was able to get a number off of the casting. 5666723-13. I'd really like to rebuild it just so I can get into it.
Posted on: 2013/5/24 2:09
No matter what it ends up being from, there's rebuild kits for all of them.
I know on Corvettes at least you can even get the shaft with the splines and gear.
AND, you can usually get one (or very similar) at a salvage yard for around $50.
Posted on: 2013/5/24 2:14
188 Posts
Any thoughts as to where I can get a rebuild kit? Jegs or Rock Auto maybe?
Posted on: 2013/5/24 23:00
Never had to buy one Frank.
Posted on: 2013/5/25 0:09
joeld Re: Steering box
Possibly a drive-line shop?
Posted on: 2013/5/25 0:36
188 Posts
Believe it or not I found both a rebuild kit or a remanufactured box at Ecklers. Thanks for all your inputs.
Posted on: 2013/5/27 3:19
Schrade Re: Steering box
You going to put it in the C4?
My '87 had that 'sleeping sickness' that many early c4's had in the steering when cold, but I think that was a different steering function...
Posted on: 2013/5/27 4:11
188 Posts
Nope. This steering box goes into my 1955 CJ3B Willys Jeep. I posted it here because these guy's really know their stuff. I also posted it on a Willy's Jeep Forum and as of yet have not heard a thing. This Site is hands down the best.
Posted on: 2013/5/27 17:40
CentralCoaster Re: Steering box
Problem with rebuild kits is they don't give you new gears. If the gears are too worn the box is worthless, according to 2 rebuilders I spoke to. They do their best to pick through the useable gears and shim/adjust them properly. That screw and jam nut on top is where you adjust lash.
I took the opportunity to swap the box for a variable ratio box from Redhead. Less sensitive in the middle of travel and more steering at the ends of travel for parking and tight maneuvers. I don't know if those are available for the manual boxes.
Posted on: 2013/6/5 15:35
188 Posts
Thanks all for your help.
Posted on: 2013/6/13 16:18
