kenvetted | Alternator question | ||
My Alternator died... I was stuck and didn't want to wait for shipping so I got this one for 95 bucks.... Did I make a mistake? Should I order a really great one as a back-up and what kind should I get?
1991 C4 I thought it would be simple to replace.... I found it to be a huge pain! http://www.oreillyauto.com/site/c/sea ... 041286&keyword=alternator |
Posted on: 2013/6/30 1:02
Matatk | Re: Alternator question | ||
Link won't work for me, maybe because I am on my phone.
Most of the parts store alternators have questionable quality. Some people have had good luck with them, though. I prefer having the gm alternator rebuilt locally. As far as replacing it, the job really shouldn't be too tough. What part did you find the hardest? Matthew |
Posted on: 2013/6/30 3:37
TommyT-Bone | Re: Alternator question | ||
Ya, It's hit or miss. I'd run it and see how it works out. It came with a warranty, right? I changed out a perfectly good GM alternator once only to find that was not the problem. It's replacement has run fine for over 5 years now. |
Posted on: 2013/6/30 11:50
BillH | Re: Alternator question | ||
I'm running a NAPA rebuilt, 5 years so far.
Posted on: 2013/7/1 0:28
vetteoz | Re: Alternator question | ||
A breaker bar to take the tension off the serp belt and 2 bolts to undo, one of the easiest jobs on a C4 |
Posted on: 2013/7/1 9:26
bogus | Re: Alternator question | ||
Ken - take your original alternator over to Astro Electric in Lomita and have them rebuild it. $100, new diodes, brushes, done.
Posted on: 2013/7/2 21:57
kenvetted | Re: Alternator question | ||
Thanks, I ended up taking it to shop to replace the alternator. I saved mine - how do I tell if it's the original? If it is, I will have it rebuild and Astro Electric. When I tried to replace it, I cut my wrist and hands... they should have a lot of sharp edges under the hood of my 91 Vette. It may have easier with the right tools. But I gave up and towed it to a shop... grrrr....
Posted on: 2013/7/10 3:57
Ken, if you ever have to replace it again, buy something called a serpentine belt tool from Harbor Freight for about $25. You use it to relive pressure on the tensioner and get the belt off...then you can remove the alternator without tension on it. You can also use a breaker bar like vetteoz mentioned, but the serpentine belt tool works a little better.
Posted on: 2013/7/11 3:30
Geardo | Re: Alternator question | ||
I just bought a new Remy Gold from Rockauto $68
Posted on: 2013/8/14 18:59
