305 user(s) are online (261 user(s) are browsing Forums)
nbergma The roof snaps and pops on my 2006 Corvette
Fresno, CA
19 Posts
I bought a one-previous-owner 2006 Corvette in July 2013. Since the day I purchased the car I have noticed that when I got over bumps, when I am on uneven ground or pavement, sometimes even when accelerating from a stop or going around corners my roof makes snapping and popping noises. I loosened the latches that secure the roof and reseated the roof and re-secured the latches but the roof still does the same thing.
I came across some information that GM had issued a couple of recalls for the roof panels of 2005-2007 Corvettes because the adhesive that secures the panel to the panel frame was defective or ineffectively applied. The fix in the original recall in 2006 was to inject some foam-type adhesive under the roof panel. Apparently that didn't resolve the problem because GM later issued a revised recall where they would install a completely new roof on vehicles that were still experiencing the problem.
According to the service records that my local dealership, Hedrick's Chevrolet here in Fresno, California, was able to obtain from the two dealerships that the original owner took the car to, both of the recalls were applied to my Corvette, yet I'm definitely still hearing a lot of the snapping and popping noises that the recall notice says is a symptom of the poor adhesion problem.
Does anyone else with a C6 hear the same kinds of sounds from your roof? Maybe this is just a normal thing that I need to get used to? Or is there another recall that I'm not aware of that I need to check into for the same problem?
Maybe I'm worried over nothing. Any feedback would be greatly appreciated.
Posted on: 2013/9/5 3:27
teebee Re: The roof snaps and pops on my 2006 Corvette
12364 Posts
Not that many C6 owners here that would fit in that year range.
Posted on: 2013/9/5 3:43
Matatk Re: The roof snaps and pops on my 2006 Corvette
Apparently a common issue....you may try lubricating certain points or adjusting the handles slightly....check here:
http://m.corvetteforum.com/c6-corvett ... ise-primer-long-post.html
Posted on: 2013/9/5 4:19
Ultraman Re: The roof snaps and pops on my 2006 Corvette
14739 Posts
My 2010 does the same thing....I find if the music is loud enough I can't hear it pop....or my wife asking what those noises are...
Yes it's a common glitch or bitch with the C6's and mine was fine until I started taking the top on and off. Sooo I am going to look into it. If the quick fixes don't work I have heard they will replace the old latches with a redesigned newer set of latches. Which must have started in late 10 or 2011. You don't seem to hear the guys with the 11-13's complaining as much. Mine is an early 10 (1834) made on Sept 22nd of 09.
My hearing isn't the best and I like the window down a lot and or the music up as I'm singing my favorite songs....so I do ignore all the popping going on....
Let us know if the new latches work.....
Posted on: 2013/9/5 12:55
bogus Re: The roof snaps and pops on my 2006 Corvette
In the C4 world, we added little felt strips to the sides. That made the top fit a bit snugger.
Will it help here? donno...
Posted on: 2013/9/5 15:38
LD85 Re: The roof snaps and pops on my 2006 Corvette
Indianapolis, Indiana
784 Posts
My 05 does it a little, not much. I added silicone to the rubber parts, seemed to help cause i don't notice it much any more.
Posted on: 2013/9/6 12:18
2005/Z51
