247 user(s) are online (221 user(s) are browsing Forums)
Also known as NHMS....
383tpimachine Building a boost friendly 400
Corpus Christi
976 Posts
So looking for a pretty bulletproof setup. Looking to make 650rwhp but want the ability to change a pulley and jump to 800-850.
So far looking at:
Dart 4.125 SHP block
http://www.summitracing.com/parts/DRT-31161211/
callies dragonslayer 3.75 crank
Diamond pistons for 6inch rod
http://www.cnc-motorsports.com/diamon ... h-pistons-4-125-bore.html
callies 6 inch rods
http://www.summitracing.com/parts/cpi-u19135/overview/
or
http://www.summitracing.com/parts/cpi-a6000cs2a2ah/overview/
And ARP hardware throughout
How does this all look? CR will be 9.5:1.
I have heard the compstar will be fine but a rating of 700flywheel is unnerving.
Posted on: 2013/10/18 1:33
1970 El Camino-Awaiting LSX
bogus Re: Building a boost friendly 400
I donno about the 400 block. The factory ones were not all that strong.
You could do all that on a 383 conversion.
Posted on: 2013/10/18 6:45
istter1 Re: Building a boost friendly 400
Bakersfield Ca
2336 Posts
My 383 is 9.5-1
I would talk to Dave again love my stroker
jpg  stroker almost ready.jpg (102.08 KB)
5144_52613458b6821.jpg 612X816 px
jpg  389443_149560225189930_969696859_n.jpg (73.02 KB)
5144_5261349032d9d.jpg 612X816 px
Posted on: 2013/10/18 13:16
Carol Burnett
BrianCunningham Re: Building a boost friendly 400
Compression seems high
which blower?
Intercooler? Math?!
Posted on: 2013/10/18 21:26
compression is fine if the boost is kept down...
low boost, higher compression = throttle response from hell!
What compression:boost ratio are you running?
Posted on: 2013/10/18 21:52
383tpimachine Re: Building a boost friendly 400
Corpus Christi
976 Posts
DART SHP 400 block. Good to 1500 hp. No steam ports and splayed 4 bolt mains. Should be the strongest piece of the engine.
which blower?
Intercooler? Math?!
9.5 is standard for most applications now that I have followed. Just will need to drop timing down with iat's on the hotter days.
V7 YSI. Intercooler will either be a LARGE A2A or a midrange A2W.
The intercooler is dependant on how it looks once I delete the AC and see what I can fit. The A2W will be mor compact but I want to avoid running the water, depending on another pump, and adding the weight.
Boost will be pulley specific. Plan to start with 14lb pulley and go up or down depending on power level from there.
Heads are coming from TEA and will be using some MLS gaskets.
Posted on: 2013/10/18 23:01
I'd be worried about the cooling
it's hard enough to keep a supercharged engine cool
power depends on how fast you spin blower
Posted on: 2013/10/19 18:11
under normal conditions - meaning cars with airflow - that would work.
The C4 does not have very good under hood air flow.
I would get a highrise hood to allow the heat out.
And BC is right, blower speed is the key to power... same applies to turbo's...
My concern with the 400 block is the limits on heads and intakes... the deck height is different. Also, the OEM 400 had some seriously thin cylinder walls. It was just pushing the SBC to a limit. I know that the aftermarket has some bad ass blocks, but this just doesn't sound like a practical fix.
Either go smaller, or go nuts and do a small big block.
Personally, a 383 will do all of this... without needing custom bits... AFR heads that fit... intake options...
Posted on: 2013/10/19 23:53
Corpus Christi
976 Posts
Dewitts, spal puller, spal pusher, and an upgraded water pump. If that doesnt work I will take out the fog lights and even further if that doesnt work I will cut up the front license plate hole.
Read above for underhood flow. I also have my custom hood going on with the SS scoop in the front. Will have some holes in the rear to allow it to escape as well.
As for the strength of the block
"The new Dart Special High Performance Chevy small block engines are manufactured from high-nickel iron for superior strength and feature siamese cylinders with 4.000 or 4.125 in. bore sizes. The cylinder walls are a minimum of .230 in. thick at a 4.165 in. bore. The Dart Special High Performance blocks are machined using precision, digital CNC equipment and are virtually ready to assemble right out of the box after a final cylinder hone. The decks are even and parallel within .002 in., and the lifter bores, cam, and main tunnels are finished. The Dart Special High Performance blocks are designed for compatibility with stock components, so no costly special parts are required for assembly."
I did my research on this piece to use a stock block or aftermarket. These blocks have been high 7s and are street driven as 440s cube motors.
I will be starting with the first pulley I ordered and get a new, likely bigger, pulley to slow the blower down where I get the power I want.
Intake is a HSR highly ported.
Heads will be in the 205-215 range with a cam matched to the head flow and my intended purpose.
The rods are my biggest concern with either the compstar or the ultras.
Compastars survive in 900rwhp LSx cars but I have not found anything in gen 1 performance applications.
Posted on: 2013/10/20 13:53
PeteK Re: Building a boost friendly 400
All external dimensions are the same for a 400 block. Any "traditional" small block head or intake, and headers will fit.
Ford guys have fits when the jump from the 302 block platform to the 351 block platform.
In regards to cylinder wall thickness, my experiences are opposite. Post 1977 small blocks (regardless of size) have thin cylinder walls.
The 400's that I have been involved with have sonic checked thicker than the typical 1 pc rear main seal block that is the norm in todays builds.
I never did understand the heat concern with a 400 block, and aluminum cylinder heads. Old wives tale that I have never seen happen.
Posted on: 2013/11/10 14:21
So far looking at:
callies 6 inch rods
or
Great parts choices in my opinion.
Not only are the crank and rods great quality, but they tend to hold their dimensions years later.
My piston of choice is the SRP.
But the best balances you can afford on it, and best flexplte as well.
Posted on: 2013/11/10 14:33
I just noticed the pistons you listed are 4032 alloy.
For the power you intend to make, and considering the boost, you may want to consider a piston with 2618 alloy.
Food for thought.
Posted on: 2013/11/10 14:51
Pete - I stand corrected... thanks for the info!
A lot of old time engine guys never did like the 400... perhaps it was an emissions engine?
Posted on: 2013/11/14 19:13
There are 3 issues on a stock 400 block that contribute to the heat issue, in my opinion.
The cylinder walls are siamesed, so coolant flow is slightly restricted (restricted may be the wrong word, but close enough).
Connecting rods are approx. 1/4 inch shorter than other small blocks, so the side loading on the cylinder wall was greater.
All production 400's had crappy iron heads.
In a performance build, the rod used is normally 6 inch, so that brings the side loading in line with a stock 350.
One thing is certain. If building a 400 or so cube small block and boosting it to the 700 hp level, heat will be an issue that will need mitigation.
The siamesed cylinders (in my opinion) are such a tiny portion of the equation, that is not worth thinking about.
Posted on: 2013/11/14 23:07
Corpus Christi
976 Posts
Thanks pete for the advice. I will look into some similar dimension pistons made of 2618.
Posted on: 2013/11/15 2:54
Went with the shorter rods
Why?
Better ring sealing
Posted on: 2013/11/15 19:43
Maybe weight.
Bigger piston and smaller rod still did become light enough. There wasn't enough space in the crank case for the counterweights to be increased (to allow it to remain internally balanced). GM hung the extra balancing weight on the flywheel/flexplate to achieve the goal.
Posted on: 2013/11/15 22:00
Mine's internally balanced, but he needed to go to a different crank to get it done
And it's just a 383
Posted on: 2013/11/16 13:08
Corpus Christi
976 Posts
Pete,
After looking through SRP and a few other vendors I find very few 2618 choices. CP offers a nice piece as does Racetec. Icon (never heard of them) also makes one within spec for my setup.
http://www.buyracingparts.com/pistons ... re-375-stroke-6-rods.html
http://www.buyracingparts.com/pistons ... stons-4125-3750-6000.html
http://www.cnc-motorsports.com/icon-i ... h-pistons-4-125-bore.html
Posted on: 2013/11/16 20:39
rklessdriver Re: Building a boost friendly 400
Pete,
Race Tec is owned by Wayne Brooks the former owner of JE Pistons.
ICON Pistons is the re-named Forged line from Keith Black.
There are lots of pistons out there that will work fine - you just need to have TEA or whoever does the heads make a small adjustment on the cumbustion chamber when they do the heads....
Probe's SRS pistons are 2618 alloy...
http://www.cnc-motorsports.com/piston ... 377-400-434/dish-top.html
Diamond has a shelf piston that will also work...
http://www.cnc-motorsports.com/piston ... sh-pistons4-125-bore.html
JE has a shelf piston that will work.
http://www.cnc-motorsports.com/piston ... e-pistons-4-125-bore.html
The Wiseco Pro Tru line has 3 dished piston options for the 400.
http://www.summitracing.com/search/de ... fault&SortOrder=Ascending
As far as the strength of the Compstar line of rods and cranks for what your doing - I wouldn't worry about it...
On a forced induction engine the tune up is more important than the "quality" of the parts inside. Most of the 4340 forged imported cranks and rods are plenty strong.
Posted on: 2013/11/18 14:10
Corpus Christi
976 Posts
Decided on the CP pistons. Now time to start looking at intercoolers. Yay custom pieces.
Posted on: 2013/12/4 1:24
Corpus Christi
976 Posts
Lil update:
Lil M block 400 9.3cr with mamofied 235 heads, YT shaftmount rockers, mamo cam, Hogan intake, callies dragon crank, callies billet rods, coil on plug, and YSI.
Cant wait for November to drop some serious cash in black friday sales.
Posted on: 2014/9/11 2:33
Any thoughts on using Meth/Water injection?
Posted on: 2014/9/12 0:55
Corpus Christi
976 Posts
Honestly I am still on the fence. I know it works very well but is still a crutch. Regardless it will get a IC be it A2A or A2W.
If I do A2W I will not run any meth and have to adjust some things in the cab to mount my battery and water tank in the hatch.
A2A I can do the same with a 3-5 gallon meth tank on a hobb switch. This sounds like the best plan to me but that is one more thing to go wrong and possible go BOOM.
Posted on: 2014/9/12 13:05
