215 user(s) are online (159 user(s) are browsing Forums)
bogus Brakes - The Perfect Storm?
A strange thought came to me...
We always say: Firm pedal, bad booster; soft pedal, bad master.
What if they both fail at the same time?
Doesn't that just sound sucky?
Posted on: 2013/11/23 19:28
Matatk Re: Brakes - The Perfect Storm?
It happens....mc goes bad and leaks into the diaphragm of the booster killing that as well.
Posted on: 2013/11/23 21:36
bogus Re: Brakes - The Perfect Storm?
yea... I know... but detecting it could be tricky.
the only hope is the lack of brake fluid triggering an investigation.
Posted on: 2013/11/23 22:13
josephf31 Re: Brakes - The Perfect Storm?
New Jersey
375 Posts
With a bad MC wouldn't the pedal go to the floor?
Posted on: 2013/11/24 4:29
You are missing the point of the perfect storm... sure, the pedal could, but with a dead booster, it might mask or hide that for some time.
Posted on: 2013/11/24 15:26
BillH Re: Brakes - The Perfect Storm?
Ah, it's not as bad as heading into turn 1 @ 125 with your buddy's wife in the right seat (first timer) and the pedal starts to go down then gets hard with the Service ABS light going crazy................. that was knda stormy.
Posted on: 2013/11/24 21:52
I guess I'm missing the point, too. Usually the mc will give some warning before failure. Even with a bad booster, you won't get resistance pushing down.
Perhaps the tires could all fall off and the engine could catch on fire while the brakes go out. That would be a perfect tsunami.
Posted on: 2013/11/24 22:34
I am thinking that the booster can fail re the size of the damage to the diaphragm.
The master softens with age, as the seals wear...
the perfect storm.
It strikes me as being plausible on cars with higher mileage.
Posted on: 2013/11/24 23:50
istter1 Re: Brakes - The Perfect Storm?
Bakersfield Ca
2336 Posts
. Before ii got that great deal on the slotted disks for $100 for 4 from tire rack. there was a weak peda .I was losing fluis for a year or so. Just a little each month.
Turned out minor leak caused the fluid to be sucked into the power boster.
Replaces all and great breap pads. No more problems
Posted on: 2013/11/25 2:09
Carol Burnett
I am getting prepped for the same project. I realized that my master cylinder is some 12 years old and has 130k miles on it... the booster is OEM original. All 194k miles!
Posted on: 2013/11/25 19:13
BrianCunningham Re: Brakes - The Perfect Storm?
There's a o-ring that separates the two circuits
When it goes, the two are linked and can make a real mess of things
There was a post a while back where a racer went off course due to this
Posted on: 2013/11/25 22:14
oh, yea... equalized pressure would suck there.
Posted on: 2013/11/27 18:04
Don't forget the ABS is in the loop
a leak back there may go unnoticed
Posted on: 2013/11/27 20:27
ABS is kinda outside the loop.
It can fail and not effect performance of the existing hydraulics.
I am really not sure what a leak failure in the ABS would do to the braking systems...
Posted on: 2013/11/27 23:28
teebee Re: Brakes - The Perfect Storm?
12374 Posts
The ABS leaked in our 99 Volvo S80, it didn't really affect anything except the ABS light was nagging me all the time and the freaking cruise control wouldn't work when the ABS light was on. I could have lived without the ABS, cruise control, not so much. New ABS from Volvo, $1800 + installation.....How much? I found rebuilt units for $395 and had my mechanic put it in, $100.
Posted on: 2013/11/28 15:23
The problem with European cars... everything costs too damned much to fix.
Posted on: 2013/11/28 16:07
12374 Posts
That's the big reason why we got rid of it.
Posted on: 2013/11/28 16:40
I hear dat.
Posted on: 2013/11/28 19:56
CentralCoaster Re: Brakes - The Perfect Storm?
Well kinda hard to figure out where you're going, what are your symptoms?
I've had intermittent m/c leakdowns. It only happened when the car had been run awhile. Maybe the piston seal has to warm up and soften up a bit. Obviously having a working booster will help find a leak. In 85, the front and rear circuits have separate reservoirs, so it makes diagnosing fluid leaks easier. Sorry that's not very helpful to you, lol.
The booster becomes open to the engine vacuum only after you move the pedal a bit. So in theory you should be able to pull a vacuum on it with a hand pump as long as the pedal is pushed/held in. It's got some volume in there so it'd take awhile to pump down.
Stabbing the booster should cause the idle to bump up if it is leaking enough.
It may make a whoosh sound by your feet, but that doesn't mean anything. It sucks air from the car interior under normal operation.
I still have the original booster on my 85.
Posted on: 2013/11/30 6:01
That's the problem with....every car.
Posted on: 2013/11/30 14:03
Friend's '94 brakes felt like cr@p till we cracked the bleeder on the ABS unit.
Not all years have bleeders on the ABS units
They changed a lot over the years.
Posted on: 2013/11/30 21:15
no symptoms, just a random thought...
mostly due to the age of the parts. The master cylinder is 2001 vintage, from Advance Auto. A reman. It seems ok... but the booster is old school OEM, so it has 194k miles on the OEm booster.
Posted on: 2013/12/1 17:29
