290 user(s) are online (216 user(s) are browsing Forums)
1963 through 1967 Corvette.
cmashark lower the rear?
virginia beach, va
74 Posts
hey guys, i want to lower the rear of my car. the front is already lower than the rear, so i thought i could just swap in some longer bolts for the rear... i plan on just going to the hardware store to get the bolts, but what length and what grade should i get? i assume that i should just get some that are 1 inch longer than stock, but don't know what grade to get. thanks in advance,
chris
Posted on: 2008/3/1 3:56
1987 Coupe 2 tone white/silver, auto, Z52.
bone stock, except for Flowmaster catback and precats eliminated.
Notorious RE:lower the rear?
You want the best grade possible. If you stay with the stock size of 14mm, you'll want metric grade 10.9. If you get a 9/16 bolt as a replacement, you'll want a grade 8. A 10" bolt will give you the capability for lowering it beyond anything you'll ever want on a street car. Get a pair of locking nuts to go with whichever bolts you use and you're done.
Posted on: 2008/3/1 4:06
I hate sporks...
cmashark RE:lower the rear?
virginia beach, va
74 Posts
awesome....thank you for the quick response. tomorrow will be a fun day! lower the rear, install my breathless lights, and install my harness bar! maybe i can actually drive it afterwards! i haven't pulled it out of the garage in about a month
chris
Posted on: 2008/3/1 4:21
Steel_Blue_91 RE:lower the rear?
Burlington, NC 27217
76 Posts
It will take some time to settle, so you might have to make several adjustments to get the look you want. Get yourself a 4 wheel alignment when you're done.
Posted on: 2008/3/1 4:53
