222 user(s) are online (178 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
BrianCunningham How Chevy keeps the tire from rotating on the rim
Posted on: 2014/3/13 19:07
pianoguy Re: How Chevy keeps the tire from rotating on the rim
Yowzahh! I guess they could've just screwed 'em in like wrinkle-wall slicks ;-)
Posted on: 2014/3/13 20:34
BillH Re: How Chevy keeps the tire from rotating on the rim
20 year old problem/20 year old solution for racers/Corvettes running sticky tires.
Posted on: 2014/3/13 20:54
Matatk Re: How Chevy keeps the tire from rotating on the rim
I was gonna guess drywall screws?
"When it came back, they found that the Pirellis had rotated 360 degrees or more."
Well, if it rotated 360*......how would you know?
Posted on: 2014/3/13 22:00
U jokin' ?
Posted on: 2014/3/14 0:20
BillH wrote:
U jokin' ?
Well think about it from a purely mathematical standpoint. If 360* is a perfect circle.... then how would you know based on a simple tire marking? It would return to the same point it started at.....but yes I was joking.
Posted on: 2014/3/14 1:00
KPotter Re: How Chevy keeps the tire from rotating on the rim
Cuyahoga Falls OH
1072 Posts
Matatk wrote:
BillH wrote:
U jokin' ?
I am with Matt on this. If the tire rotates 360 degrees it is right back where it started. How can you tell ? If it rotates 365 degrees it looks the same as it would if it moved 5 degrees. Now if it were to rotate say 350 degrees, now there is something to look at.
Posted on: 2014/3/14 3:56
They said 360 cause this is just a marketing blurb, hoping that some of the viewers would recognize the term 360 say "Holly Crap, dat thing's got some power" and that those viewers would just scratch their heads if they heard 350 degrees (which is close to what the vid shows anyway).
Still just a marketing thing for something that's been happening on race tracks and dirt tracks foreva.
Now, how long is foreva?
Posted on: 2014/3/14 14:21
I would guess foreva is 360 years. But then it might be zero years. But 350 years, that's a long time.
Posted on: 2014/3/14 22:50
Matatk wrote:
I would guess foreva is 360 beers. But then it might be zero beers. But 350 beers, that's a lotta brew.
Posted on: 2014/3/14 23:42
apparently bill got a head start on those beers....
Posted on: 2014/3/15 0:25
The size of the head depends on how fast U pour the beer,
Posted on: 2014/3/15 0:43
