244 user(s) are online (174 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
Vette91 Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
Germany
70 Posts
I installed a Canton oil pan resulting in to less space for the oil filter relocation adaptor (Summit kit).
So I decided to fab a shorter one.
It is very important that you install the adaptor before boring and taping the off-axis thread in order to mark its position.
An advantage is, that one gasket is not needed anymore and the gasket which seals to the block is much better than the O-ring which came with the adaptor. I used a seal of an oil-filter. After turning and taping I DIY-anodized it.
Sealed the brass-fittings with Loctite 511:
And finally the installed adaptor ...
Best wishes
Eike
Posted on: 2014/4/13 21:32
TommyT-Bone Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
33766 Posts
There appears to be a new wave of guru creativity. I'm impressed.
Posted on: 2014/4/13 23:03
Churchkey Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
69 Posts
Very nice! Your machining skills are impressive.
The thing I like the most about your design vs the standard sandwich adaptors is that the remote oil filter can be plumbed ahead of an oil cooler. This will save the oil cooler in the event the engine grenades.
Posted on: 2014/4/13 23:24
bogus Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
awesome!!!!
Posted on: 2014/4/14 0:10
Matatk Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
Very impressive!
Posted on: 2014/4/14 11:43
rklessdriver Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
Nice work.
Posted on: 2014/4/14 12:43
BrianCunningham Re: Oilfilter Relocation Adaptor - fab a shorter one and get rid of a gasket
Nicely done
ordered one adapter for a test rig
couldn't believe how much flash was on it!
Posted on: 2014/4/15 21:30
