255 user(s) are online (213 user(s) are browsing Forums)
istter1 Thinking about mufflers again
Bakersfield Ca
2336 Posts
Don't want to break the bank No drone. on my 87.
Posted on: 2014/9/13 2:26
Carol Burnett
GRIS Re: Thinking about mufflers again
OKLAHOMA
7657 Posts
FLOWMASTERS ON MY STOCK '87-RATHER SEDATE, NO DRONE.
Posted on: 2014/9/13 3:48
Matatk Re: Thinking about mufflers again
Is that with your hearing aid turned off, or on?
Posted on: 2014/9/13 11:34
Love my factory LT4 system. Those don't drone. Neither do Corsas for $1k. Otherwise you could look at the factory style replacements in the magazines, those aren't supposed to drone, either.
Posted on: 2014/9/13 11:35
OKLAHOMA
7657 Posts
WHAT'D YOU SAY?
Posted on: 2014/9/13 12:52
istter1 Re: Thinking about mufflers again
Bakersfield Ca
2336 Posts
huh
lol
Posted on: 2014/9/13 23:55
Carol Burnett
rklessdriver Re: Thinking about mufflers again
Find a used LT1 or LT4 exhaust system and modify it to fit your L98.... Easy to do.
Heck I gave mine away to a guy for that purpose when I put the Corsa on my 92... now I wish I had it back on the car....
Posted on: 2014/9/16 18:24
Also be aware, Steve, that mufflers that sound one way on a 350 will be totally different on your stroker. My magnaflows were deep and rumbly on my stock motor, but the stroker and headers made them unbearably loud/droning.
Posted on: 2014/9/16 22:51
Bakersfield Ca
2336 Posts
A answer I was looking for. There is a big difference from the time I installed the Stroker.
Posted on: 2014/9/17 2:19
Carol Burnett
Schrade Re: Thinking about mufflers again
If you were closer, I'd say come get the pipes that I took off my '90 Z...
Posted on: 2014/9/19 3:54
Bakersfield Ca
2336 Posts
Thanks for the offer
Posted on: 2014/9/20 4:29
Carol Burnett
Thinkin' further there Steve, my pipes (resonators) are more restrictive than LT1, LT4 pipes, I do believe...
Posted on: 2014/9/21 1:36
Bakersfield Ca
2336 Posts
were yours stock
Posted on: 2014/9/21 14:40
Carol Burnett
Bakersfield Ca
2336 Posts
Many years ago it was called resonance. In sound applications, a resonant frequency is a natural frequency of vibration determined by the physical parameters of the vibrating object
When you hear the resonance or drone, you will know it and you won't like it. It's just plain annoying and tells you that the manufacturer doesn't know how to design a muffler as far as sound control is concerned/
Corsa Performance Combats Drone With RSC Technology
By Jason Reiss
How Does It Work?
Performance mufflers typically take certain avenues to dampen sound – reflection, absorption, or some combination of the two. The sound that travels from the exhaust is a pressure wave that’s formed from pulses of alternating high and low pressure, which make their way through the air at the speed of sound – no surprise there, right? Engines create those pulses when the exhaust valves open at different times, and the high-pressure gases escape from the cylinder and enter the exhaust system. The gases stack up with the lower-pressure molecules in the pipe, which leaves an area of lower pressure behind it in the pipe. Now multiply that by four, or six, or eight cylinders, and you have an exhaust tone as the pressure pulses reach your eardrum.
I don't have the money for this.
Posted on: 2014/9/21 15:50
Carol Burnett
Bakersfield Ca
2336 Posts
Lt1 $100-$125 and I pay shipping . owner claims only 9000 miles on it before change.
Is that a muffler where my third cat would be.
Any opinions
jpg  lt1.jpg (119.47 KB)
5144_5420b57391e79.jpg 800X586 px
Posted on: 2014/9/22 23:51
Carol Burnett
Bakersfield Ca
2336 Posts
Is that a resonator where my third cat would be.
Any opinions
being offered a deal on this can this be cut up and shipped or does it have to go freight? My third cat is where the resonator is in the middle. or do I leave that resonator there.
Two pre cats and a third cat in California is nuts. I realize they are for I believe warm-up in cold areas
Posted on: 2014/9/23 0:59
Edited by istter1 on 2014/9/23 1:32:28
Carol Burnett
That is the resonator in the middle. That is a decent price but shipping will be expensive.
He can cut it and you can have it welded or use band clamps.
Posted on: 2014/9/23 1:00
Bakersfield Ca
2336 Posts
Ya I figured out it was called a resonator after my post
Posted on: 2014/9/23 1:35
Carol Burnett
Yeah - they were stock. VERY restrictive. Some of the guys on the Z boards say 2" headers + 3" open pipes (with mufflers) is good for 22 - 25 HP more.
I couldn't see it, but one of them is THE Z authority - Marc H.
Biggest gain is WAY COOLER running temps. I KNOW it is running AT LEAST 15' cooler with wrapped 2", + 3" exit pipes. THAT'S something that some of the other guys could NOT see. Last Winter, 1' cooling fan (set for 205'), would come on @ about 18 minutes from cold start, while tuning, in carport, outside temps upper 40's.
Now, since May exhaust install, ONLY this past August, did local stop n go driving get it up to 205'. I had to turn on A/C to check fan operation, since fans didn't come on all Spring + Summer.
Posted on: 2014/9/24 17:30
Bakersfield Ca
2336 Posts
Very interesting. I know when my precats went out they were so hot they boiled the brake fluid out of slave. Took over a year to find the heat source.
Posted on: 2014/9/25 3:01
Carol Burnett
Bakersfield Ca
2336 Posts
Just picked up LT1 exhaust at beach.
jpg  IMG_20140927_191414.jpg (87.61 KB)
5144_54277b2b47d8a.jpg 405X720 px
jpg  IMG_20140927_184745.jpg (125.06 KB)
5144_54277cd0e8ebf.jpg 720X405 px
jpg  IMG_20140927_184720.jpg (92.66 KB)
5144_54277cfa4f7af.jpg 720X405 px
jpg  IMG_20140927_184924.jpg (85.99 KB)
5144_54277d202db4b.jpg 720X405 px
Posted on: 2014/9/28 3:11
Carol Burnett
Bakersfield Ca
2336 Posts
http://youtu.be/SUtBzWi3z1w
Great video
where do I get hangers for exhaust tips?
How long are the springs on the hangers.
Can see on the video.
Any other advice or pointers
5144_542796399a239.jpg 720X405 px
Posted on: 2014/9/28 4:56
Carol Burnett
You can pick up the hangers from ebay or a corvette recycler. It is a set of three - one front off the transmission and two rear off the differential (right and left sides).
Posted on: 2014/9/28 11:50
Bakersfield Ca
2336 Posts
Thanks
Posted on: 2014/9/28 13:06
Carol Burnett
Bakersfield Ca
2336 Posts
Ordered these just the other day they almost look brand new. Dino's Corvette Salvage LLC. Quick service the right part I believe.
jpg  IMG_20141002_175717.jpg (151.97 KB)
5144_542df9bf45bef.jpg 720X405 px
Posted on: 2014/10/3 1:17
Carol Burnett
What was the cost? I think a set is in the $80-100 range.
Posted on: 2014/10/3 2:14
Bakersfield Ca
2336 Posts
$45 set
$15 shipping pretty good deal
Posted on: 2014/10/3 2:44
Carol Burnett
Very fair price.
Posted on: 2014/10/3 10:56
Bakersfield Ca
2336 Posts
more searching tomorrow
Posted on: 2014/10/4 1:03
Edited by istter1 on 2014/10/4 1:51:42
Carol Burnett
Steve, here is how my guy installed my setup using flex pipe. Just an idea for you. I'm not sure how you plan on doing it with the cats since California is so strict.
Posted on: 2014/10/4 12:44
Bakersfield Ca
2336 Posts
Wow thanks for the picture.
My idea was to cut back pipes to connect to cats. Flex pipes makes it look simple.
Posted on: 2014/10/4 14:59
Carol Burnett
I like it because it makes the exhaust system less rigid. I was constantly retightening collector flange bolts before.
Posted on: 2014/10/4 17:51
Bakersfield Ca
2336 Posts
Good point Just got home . Doing some reading on tuner pro so I can check data on DTC. Re setting light
Posted on: 2014/10/4 20:38
Carol Burnett
I should have put in some of that flex-pipe to kill some drone. I ended up wrappimg all the way back, and it helped a lot; not enough tho'...
Posted on: 2014/10/10 14:45
jonszr1 Re: Thinking about mufflers again
Lone Pine, CA
do you need the ones at the back of the car that bolt to the mufflers. if so I have 2that I will just give to you. let me know
Posted on: 2014/10/25 9:01
Bakersfield Ca
2336 Posts
Brad all I have is what is in the pictures.
5144_544bc471119ed.jpg 720X405 px
Posted on: 2014/10/25 15:41
Carol Burnett
Bakersfield Ca
2336 Posts
Well this weekend will be the time to measure and decide how much to cut and where I will hook the hangers from the exhausts to. Important things using flanges or weld pipes to cats.
5144_54517e9162e3a.jpg 720X405 px
5144_54517f0d9a972.jpg 720X405 px
jpg  2012-02-24144216.jpg (71.77 KB)
5144_545180eeafb63.jpg 800X600 px
Posted on: 2014/10/30 0:01
Carol Burnett
On a stock car, the double spring hanger attaches to the transmission. Not sure how yours will work with the TKO. The other two hangers go on the differential.
Posted on: 2014/10/30 12:15
Bakersfield Ca
2336 Posts
Thanks for the info
good picture
Posted on: 2014/10/30 13:33
Carol Burnett
Bakersfield Ca
2336 Posts
found some of my tko 600 install. looks like there has to be something to hook the hangers to
jpg  tko6001.jpg (273.13 KB)
5144_5453118ebc514.jpg 909X682 px
Posted on: 2014/10/31 4:35
Carol Burnett
The front exhaust hangers aren't that important, IMO.
After I installed my long tube headers on the 92, the front hangers won't fit any more (didn't line up with the Exotic Muscle extension pipes). So I just have the rear hangers on the differential and the muffler hangers on my 92.
I would take your old L-98 Y Pipe and cut each side off just before it bends - so that you have 2 straight sections comming off the Pre-Converter ball flanges.
Should be pretty easy to splice that to the LTX catback.
Posted on: 2014/11/3 14:44
Bakersfield Ca
2336 Posts
Makes it sound to easy. Hope to have time over the holidays.
Steve
Posted on: 2014/11/6 2:02
Carol Burnett
