| teebee | Clutch fluid change | ||
One of the first things Marcus said to me when we met and he looked at my car was, "Make sure you change the clutch fluid." So, I decided to do some research and after reading many threads I thought I ought to go check out the clutch fluid in my car. I've had it about 6 weeks now and love the manual shift. I haven't had a manual since I had my 64 coupe 40 years ago. Anyway, what I found when I popped the hood and actually looked at the slave cylinder was it appeared very dark. I knew this wasn't right (after reading and watching rangers' videos http://www.rangeracceleration.com/Clutch_Care.html, Thanks Ranger!). I bought a syringe and sucked out as much of the old stuff as I could, there was still a lot of black crap in the bottom. So with a blue towel I was able to wipe all the crap out. I shot the junk into a clean butter tub and it looked like very strong coffee. So I filled the reservoir with clean and pumped the clutch pedal 100 times. Checked again still very murky. Repeat the process, murky still. Repeat again, better, but still a little junk in there, So one more time before I get the fluid where it is clear.
I actually found the syringe at a farm supply place, I bought the 60mL size. and surprisingly, I had a hard time finding straight DOT 4 brake fluid. Three places before I found straight DOT 4. Many places had DOT 3 and 4, but not straight DOT 4. The picture below is the results of all the fluid I sucked out, not just the first. Amazing how dark that crap is. I highly recommend that if you have a manual trans to change the fluid out often. It's easy to do, doesn't really cost much, doesn't take much time to do and you'll be saving yourself a bunch of headaches down the road. ![]() ![]() |
Posted on: 2014/11/18 0:28
2007 Atomic Orange 3LT coupe. Borla Exhaust One of Americas' proud Deplorable
Transfer
| Matatk | Re: Clutch fluid change | ||
Very nice! I always enjoy the simple methods.
Make sure not to spill on the paint ![]() |
Posted on: 2014/11/18 0:54
Transfer
| pianoguy | Re: Clutch fluid change | ||
Good reminder - I haven't done mine in a few years.
Posted on: 2014/11/18 2:56
Transfer
| Ultraman | Re: Clutch fluid change | ||
Once you get it cleaned up Tom you can just put new fluid in about once a month, that's what I do anyway. Then while you drive the car you work the clutch instead of wearing your leg out....it becomes routine maintenance.
Posted on: 2014/11/18 13:55
2002 C5 Electron Blue Roadster 2010 Grand Sport Coupe Gone but not forgotten... |
Transfer
| BillH | Re: Clutch fluid change | ||
Good job Tom, and necessary.
So, how fast will fluid discolor? Well, although timewise this isn't applicable to street cars, I bleed the calipers on the race cars every race. Under this extreme usage (and high heat) the fluid in the caliper will start to discolor in 3 sessions (that's an hour and a half). You can see why once a year on the street is a good idea. I'm not thrilled with the syphon method though (it's acceptable but not the best and I do use it on power steering) but actually bleeding the annular throwout bearing would be better. If I was lucky enough to have a C6, this would be one of the first things I would buy for the car: http://store.katechengines.com/c6-rem ... utch-bleeder-kit-p96.aspx I'd also vacuum bleed (air powered) the system. I have a vacuum bleeder but am going to pick one of these up: http://www.harborfreight.com/brake-fluid-bleeder-92924.html Using these, your fluid change now takes 10 minutes. And the bleeder works great on brakes. |
Posted on: 2014/11/18 14:51
Transfer
| teebee | Re: Clutch fluid change | ||
Those remote bleeders are the cat's meow. But I've heard they are a real PITA to install unless you are doing a clutch replacement.
Marcus, that makes good sense. About once a month would be easy to do. |
Posted on: 2014/11/19 4:00
Transfer
Transfer
