129 user(s) are online (93 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
brian difference from z51 and reg corvette
193 Posts
hi i recently bought my first corvette so i just started geting into them. ive got a 88. how can i see if its a z51 or z52 or w/e they are. also how can i tell if it is the anniversary edition.
Posted on: 2008/3/9 23:47
polish41 Re: difference from z51 and reg corvette
Watertown.SD
50 Posts
Check for your RPO sheet either under the center consol lid or in one of the rear compartments. This will tell you if it's a Z51. Anniversary units the year model ends with a three. IE 53, 63. and so on.
Posted on: 2008/3/10 0:15
If your not living life on the edge your taking up to much space.
brian Re: difference from z51 and reg corvette
193 Posts
oh so they dont do every 5 year anniversary. what is the rpo sheet and the center console was completely tore up so i cant look under there. but was does the z51 have compared to the reg.
Posted on: 2008/3/10 0:18
pappyfreebird Re: difference from z51 and reg corvette
1028 Posts
a stiffer ride
Posted on: 2008/3/10 0:32
193 Posts
a stiffer ride thats it. so i could put some z51 shocks on my vette and it would be just like a z51. and when you mean stiffer do you feel every bump you hit lol. cause i hold my breathe going over train tracks at 20mph. hit my head on the top of car also. but im 6'5 so its a really close fit anyways/
Posted on: 2008/3/10 0:42
Watertown.SD
50 Posts
Actually there's more to it than just shocks. There's springs, torsion bars, bushings, and wheel rates. You can get a copy of your RPO sheet from the NCM. It will cost a bit but it's worth it. You can also get a copy of your window sticker.
Posted on: 2008/3/10 2:06
193 Posts
Lol next dumb questions whats a NCM. sorry im 18 im still learning.
Posted on: 2008/3/10 2:13
MAXXWRENCH Re: difference from z51 and reg corvette
COLORADO
118 Posts
NCM--NATIONAL CORVETTE MUSEUM...IF YOU WANT TO KNOW FOR SURE IF YOU HAVE THE Z51 OPTION YOU CAN ALSO CALL ANY GM DEALER WITH YOUR VIN & THEY IN THE PARTS DEPARTMENT CAN TELL YOU IF YOU HAVE IT OR NOT.
Posted on: 2008/3/10 2:29
ONE SHOT, ONE KILL, I WIN
TommyT-Bone Re: difference from z51 and reg corvette
33777 Posts
For 1988 there were 1309 corvettes produced with a Z51 pkg. There were 16017 with the Z52 option. One tip for the anniversary pkg is white exterior with a white leather interior. Thank Mike Antonick for the info. Lots of info can be found in the Corvette Black Book.
Posted on: 2008/3/10 2:45
193 Posts
thanks for the info guys. on the first i move to my new house so ill take some pictures of it and post them. then once i fix everything ill post some before and after pics.
Posted on: 2008/3/10 2:47
Oaklands Re: difference from z51 and reg corvette
Morristown, TN
480 Posts
I've got an 88 myself. It has the Z52 package on it. Has a stiffer ride than the regular model. I do like the feel of it.
Posted on: 2008/3/10 3:39
jhammons01 Re: difference from z51 and reg corvette
What about under the door of the rear bins? Did you look under there?
Posted on: 2008/3/10 17:33
193 Posts
no i live downtown and had to park 4 blocks away so i didnt want to walk all the way over there. i doubt it is a z51 or z52 but im just wondering the difference.
Posted on: 2008/3/10 18:10
