Frank | Power Steering pump | ||
I've run into a problem that is at the moment keeping me from driving my Vette. Power steering went out and the old pulley is to "loose" for the new power steering pump shaft. It just slides on instead of being a press fit. Any ideas? I took the pump back and made them give me a new one but have the same results. Thanks in advance.
Posted on: 2015/3/17 20:23
EngineDoctor | Re: Power Steering pump | ||
What is the outside diameter of your new pump shaft , as opposed to your old pump shaft? Any signs of wear on the pulley itself?
Posted on: 2015/3/17 22:22
istter1 | Re: Power Steering pump | ||
I replaced mine when I installed this great 383 stroker in my 87. Lol
Ac Delco gm 88985263 ACO 36-516328 Like Dave said measure it. I have my old one in my parts nothing wrong with it can measure yours against mine. Wow sounds dirty Steve |
Posted on: 2015/3/18 1:49
Hello Steve !!!! How ya been Sir !
Posted on: 2015/3/18 2:38
Busy busy lol
Posted on: 2015/3/19 2:35
Frank | Re: Power Steering pump | ||
.796. I'm wondering if the old pump I have just replaced was from a different year C-4, say a 1996 or so. Anyone know?
Posted on: 2015/3/19 22:43
mine is 16mm
Posted on: 2015/3/21 5:23
16mm is .629
Posted on: 2015/3/21 7:56
Now your making it to easy for him Dave |
Posted on: 2015/3/21 18:40
Thanks Dave. .796 is 20.2 mm's. Now I have to find out why my pulley size is bigger than the pump shaft size. I suspect the previous owner replaced the pump or pulley with something other than OEM. Is there a difference or different pump from 1984-1996?
Posted on: 2015/3/22 21:28
Can't you simply get the proper pulley for your new pump?
Posted on: 2015/3/22 23:39
That's where I'm headed buuuttt seems odd you have to replace a pump AND a pulley (they're sold separately). Have a look at what I found below. This may be the answer.
http://www.corvetteactioncenter.com/t ... gebase/images/84co3_2.jpg Thanks for your input guy's-much appreciated. |
Posted on: 2015/3/23 21:45
Just be glad it's a Chevy FORD parts are even worse.....
Posted on: 2015/3/23 22:25
A&D ENGINES http://andengines.com |
CentralCoaster | Re: Power Steering pump | ||
The Ford pump comes with a warning label on it saying "whining noise from the pump is normal". Lol, I kid you not.
Posted on: 2015/3/24 18:16
Now that is funny !!!!
Posted on: 2015/3/24 22:27
Is it true that Fords are pushed back home so often they started making them out of Aluminum to make it easier?
Posted on: 2015/3/25 1:26
L(L...^^^^ I can tell you from experience Ford's Plastic intake manifolds are a real piece of sh** !!
Posted on: 2015/3/25 18:26
Need some help locating a power steering pump pulley for a 1984 Corvette. My local dealer says its an obsolete part. Ecklers and Rock Auto doesn't have it either. Thanks for your help.
Posted on: 2015/4/16 2:52
Matatk | Re: Power Steering pump | ||
Check with Pat (See4parts) on the other site.
$40 on ebay, you'll have to check fitment: http://www.ebay.com/itm/1984-1990-Cor ... sh=item5b0f95ab6d&vxp=mtr Check style/fitment: http://www.ebay.com/itm/1984-1991-Cor ... sh=item51cf653f33&vxp=mtr http://www.ebay.com/itm/1984-91-Corve ... sh=item4d2b8456c6&vxp=mtr |
Posted on: 2015/4/16 3:27
Thanks Mataak. Great info.
Posted on: 2015/4/23 23:25
Finally! Back on the road. Ended up buying a Pulley from Dino's Corvette salvage on E-Bay. Great guy's to deal with. I was surprised when my Chevy dealers here in San Diego told me the part is obsolete and "good luck finding one". Thanks for all of your inputs through this site. Much appreciated.
Posted on: 2015/5/30 18:26
Good to hear!
Posted on: 2015/5/31 0:07
bogus | Re: Power Steering pump | ||
Dealers are limited to their catalogs... and they are unwilling to consider third party (ie, used) sources. The only ones that do are body shop folks... mostly cause the insurance companies force them into it!
I am glad you found one! Dino's good people, too. Very knowledgeable... for the most part... he and I had a bit of a disagreement on the function of the Dual Mass Flywheel... but that's not my fault he isn't aware of its importance... |
Posted on: 2015/5/31 19:00
