289 user(s) are online (263 user(s) are browsing Forums)
Frank Power Steering pump
188 Posts
I've run into a problem that is at the moment keeping me from driving my Vette. Power steering went out and the old pulley is to "loose" for the new power steering pump shaft. It just slides on instead of being a press fit. Any ideas? I took the pump back and made them give me a new one but have the same results. Thanks in advance.
Posted on: 2015/3/17 20:23
EngineDoctor Re: Power Steering pump
La Habra Ca.
791 Posts
What is the outside diameter of your new pump shaft , as opposed to your old pump shaft? Any signs of wear on the pulley itself?
Posted on: 2015/3/17 22:22
istter1 Re: Power Steering pump
Bakersfield Ca
2336 Posts
I replaced mine when I installed this great 383 stroker in my 87. Lol
Ac Delco
gm 88985263
ACO 36-516328
Like Dave said measure it. I have my old one in my parts nothing wrong with it can measure yours against mine.
Wow sounds dirty
Steve
Posted on: 2015/3/18 1:49
Carol Burnett
La Habra Ca.
791 Posts
Hello Steve !!!! How ya been Sir !
Posted on: 2015/3/18 2:38
Bakersfield Ca
2336 Posts
Busy busy lol
Posted on: 2015/3/19 2:35
Carol Burnett
Frank Re: Power Steering pump
188 Posts
.796. I'm wondering if the old pump I have just replaced was from a different year C-4, say a 1996 or so. Anyone know?
Posted on: 2015/3/19 22:43
Bakersfield Ca
2336 Posts
mine is 16mm
Posted on: 2015/3/21 5:23
Carol Burnett
La Habra Ca.
791 Posts
16mm is .629
Posted on: 2015/3/21 7:56
Bakersfield Ca
2336 Posts
EngineDoctor wrote:
16mm is .629
Now your making it to easy for him Dave
Posted on: 2015/3/21 18:40
Carol Burnett
188 Posts
Thanks Dave. .796 is 20.2 mm's. Now I have to find out why my pulley size is bigger than the pump shaft size. I suspect the previous owner replaced the pump or pulley with something other than OEM. Is there a difference or different pump from 1984-1996?
Posted on: 2015/3/22 21:28
La Habra Ca.
791 Posts
Can't you simply get the proper pulley for your new pump?
Posted on: 2015/3/22 23:39
188 Posts
That's where I'm headed buuuttt seems odd you have to replace a pump AND a pulley (they're sold separately). Have a look at what I found below. This may be the answer.
http://www.corvetteactioncenter.com/t ... gebase/images/84co3_2.jpg
Thanks for your input guy's-much appreciated.
Posted on: 2015/3/23 21:45
La Habra Ca.
791 Posts
Just be glad it's a Chevy FORD parts are even worse.....
Posted on: 2015/3/23 22:25
CentralCoaster Re: Power Steering pump
The Ford pump comes with a warning label on it saying "whining noise from the pump is normal". Lol, I kid you not.
Posted on: 2015/3/24 18:16
La Habra Ca.
791 Posts
Now that is funny !!!!
Posted on: 2015/3/24 22:27
188 Posts
Is it true that Fords are pushed back home so often they started making them out of Aluminum to make it easier?
Posted on: 2015/3/25 1:26
La Habra Ca.
791 Posts
L(L...^^^^ I can tell you from experience Ford's Plastic intake manifolds are a real piece of sh** !!
Posted on: 2015/3/25 18:26
188 Posts
Need some help locating a power steering pump pulley for a 1984 Corvette. My local dealer says its an obsolete part. Ecklers and Rock Auto doesn't have it either. Thanks for your help.
Posted on: 2015/4/16 2:52
Matatk Re: Power Steering pump
Posted on: 2015/4/16 3:27
188 Posts
Thanks Mataak. Great info.
Posted on: 2015/4/23 23:25
188 Posts
Finally! Back on the road. Ended up buying a Pulley from Dino's Corvette salvage on E-Bay. Great guy's to deal with. I was surprised when my Chevy dealers here in San Diego told me the part is obsolete and "good luck finding one". Thanks for all of your inputs through this site. Much appreciated.
Posted on: 2015/5/30 18:26
Good to hear!
Posted on: 2015/5/31 0:07
bogus Re: Power Steering pump
Dealers are limited to their catalogs... and they are unwilling to consider third party (ie, used) sources. The only ones that do are body shop folks... mostly cause the insurance companies force them into it!
I am glad you found one! Dino's good people, too. Very knowledgeable... for the most part... he and I had a bit of a disagreement on the function of the Dual Mass Flywheel... but that's not my fault he isn't aware of its importance...
Posted on: 2015/5/31 19:00
