252 user(s) are online (161 user(s) are browsing Forums)
CorvetteBob Uh Oh...
1409 Posts
While daydreaming in the garage I noticed the plug on the " brake pressure differential switch" was out of whack. Closer inspection revealed the female plugs from the connector were broken and remaining on their male sides.
After looking around on the net I've found that this switch is , for me, unfindable, and the repair pigtail is discontinued.
This pigtail is oval shaped with one wire coming in and two connector female holes in it. It is black and has a "claw" on each end of the oval. It's flexible to aid removal.
Anyone here have an idea on how to find one?
Thanks.
Posted on: 2016/7/31 16:09
j3studio Re: Uh Oh...
Is this for the 1989?
Posted on: 2016/7/31 16:20
CorvetteBob Re: Uh Oh...
1409 Posts
Yes, it's for the 89.
I'm wondering if this is one of those things that was superseded by a new switch with a new pigtail, but I've had no luck finding info on that either.
Posted on: 2016/7/31 16:26
BillH Re: Uh Oh...
Don't know what your pigtail looks like but, might be here:
http://www.ebay.com/sch/Sensors-Switc ... 7E1989%7E-%7E-&MYear=1989
Posted on: 2016/7/31 16:39
joeld Re: Uh Oh...
I went thru this several years, but just looking for a pig tail. Never did find a new replacement, had to buy a used one.
Good luck
Posted on: 2016/7/31 17:13
bogus Re: Uh Oh...
check rockauto.com... they have lots of connectors available.
Posted on: 2016/7/31 19:19
Schrade Re: Uh Oh...
Any pics?
Posted on: 2016/7/31 19:55
joeld Re: Uh Oh...
I had this bookmarked for some reason, you might get lucky.
https://corvetteparts.com/item/switch- ... al-warning-lamp-1984-1989
Posted on: 2016/7/31 22:20
GOLDCYLON Re: Uh Oh...
Peoria, Arizona
23 Posts
Schrade wrote:
Any pics?
Concur that would be helpful
Posted on: 2016/8/1 0:14
GOLDCYLON - 91 ZR-1 #2014
Resized Image380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors,/R Baer Eradaspeed Rotors with Wilwood 6 piston front calipers
1409 Posts
I'll try to get pics up, but the best/closest I've seen so far is from the link Joel's offered. Go ther and then search
290748
While mine only has one wire, the one shone in the link to 290748 has two wires.
I looked on RockAuto, called every store I could find, and no one has a listing.
I may have to re-create a plug out of the one I have if I can't find a parts car or a listing or something.
And once again, thanks very much to all for trying to help.
Posted on: 2016/8/1 0:51
BrianCunningham Re: Uh Oh...
Painless may have the connector as well
There _might_ be a part # in the manual
Posted on: 2016/8/1 22:26
1409 Posts
I saw a part number on the fsm wiring diagram, maybe I'll get that out this week and try that.
Painless is a good idea as well.
Thanks!
Posted on: 2016/8/2 0:37
1409 Posts
I don't have a pic, but I have one on the way from Shawn at Corvettenutz.
(I hope I got his business name right)
I also have some LTx exhaust hangers coming with it.
Shawn's a good, reliable guy to deal with. I highly recommend him for C4 parts.
Posted on: 2016/8/18 22:44
istter1 Re: Uh Oh...
Bakersfield Ca
2336 Posts
Call
Ron Francis Wiring.
You can ask Ron by email from web sight
great guy
Posted on: 2016/8/18 23:53
Carol Burnett
1409 Posts
This past week I got the part from Shawn at vettnuttz. It's used, but in absolutely in excellent condition. I also got some LTx exhaust hangers from him that look like they came off a one year old Arizona car.
He's a good guy to deal with.
Posted on: 2016/8/28 16:30
