198 user(s) are online (160 user(s) are browsing Forums)
jimmers Replace Rear Axle Seal
Winnipeg, Manitoba Canada
211 Posts
Hey everyone. My driver side rear axle seal is leaking and I'm wondering if the entire differential needs to come out to replace it? If so, any tips? Easy job? Thanks!
Posted on: 2016/9/16 20:20
Matatk Re: Replace Rear Axle Seal
I will have to check the FSM, as I've never done it. Not sure if you need to remove the diff from the car first. Bear with me.
Posted on: 2016/9/17 11:54
istter1 Re: Replace Rear Axle Seal
Bakersfield Ca
2336 Posts
Good luck.
Posted on: 2016/9/17 12:45
Carol Burnett
jimmers Re: Replace Rear Axle Seal
211 Posts
I've read through my FSM, but to be completely honest, I know nothing about differentials. I'm pretty sure I have to, but I wanted to make sure there wasn't a shortcut or something. Thanks for the help!
Posted on: 2016/9/17 17:00
rklessdriver Re: Replace Rear Axle Seal
It would probably be easiest to remove the diff from the chassis.
The cover/batwing has to come off in order to get the snap ring off the inner stub axel... which has to come out to change the seal.... which means the halfshaft has to be separated from the inner stub axel.
Pretty involved job either way for a simple side seal. Not difficult, just involved. I can have the diff out of a C4 in about 45mins.
Posted on: 2016/9/18 2:35
211 Posts
Thanks for the reply. That's not really what I wanted to hear, but I kind of figured it was the case.
Posted on: 2016/9/18 12:34
PeteK Re: Replace Rear Axle Seal
If you have not yet done the repair, make sure you have a stout set of lock ring pliers on hand. The clips that hold the axles in are a BEAR to pop loose.
Posted on: 2017/1/22 14:08
