mojo92 | Car running funny (Help) | ||
I drive the car everyday and it has been running fine. I just went to eat tonight and it ran fine but on the way home it started skipping really bad . Even at high speeds it runs like crap! Could it be the fuel filter, spark plugs or the spark plug wires? If I hold the gas just aliddle in park it idles up and down and if I give it just a tad more gas it idles really ruff. What is the best plugs to put in a 91 coupe and what is the best wires to have.
Posted on: 2008/3/22 5:24
bogus | Re: Car running funny (Help) | ||
I like Taylor wires and NGK plugs.
If there hasn't been a tune up or filter replacement, I would go ahead and do it. I would also remove and clean the throttle body. |
Posted on: 2008/3/22 5:25
BillH | Re: Car running funny (Help) | ||
I'll second what Bogus said, Taylors and NGKs are all I use.
Plugs, wires and fuel filters are maintainence items. Cleaning the TB is easy and inexpensive. If you know these items are in good shape, your diagnosis will be a little easier. |
Posted on: 2008/3/22 14:54
I fixed you sig... the img tags are silly... now... can you make the picture just a little bit smaller??? thanks!
Posted on: 2008/3/22 21:10
JonnyAngle | Re: Car running funny (Help) | ||
I use the Delco Plugs and wires and have had no problems
Posted on: 2008/3/22 23:08
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
mojo92 | Re: Car running funny (Help) | ||
I replaced the plugs and wires, plus I put a new fuel filter on and come to find out it was the EGR value. Now I have to take the intake off just to replace it. Now I can also clean the TB. Is there a easier way to replace the EGR value?
Posted on: 2008/3/25 0:19
ninetyfivevette | Re: Car running funny (Help) | ||
Mine has been off for a while- but what is in the way? I would think that after removing the AIR tube and removing the oil pressure sender you should be good to go. You may only have to rotate the sender out of the way- I wish I could remember.
Posted on: 2008/3/25 1:11
it's reachable.... the EGR on a 92 doesn't require removing the intake.
a 10mm gear wrench will get it. |
Posted on: 2008/3/25 2:34
Travis93 | Re: Car running funny (Help) | ||
If anything you could pull the fuel rail but I would not pull the intake just to get at it.
Posted on: 2008/3/25 20:16
hulagan808 | Re: Car running funny (Help) | ||
sudden idle problems are (almost) always from unmetered air, weather internal (IAC-egr-intake manifold-MAS-tps-MAP) or external (hoses-intake manifold-exhaust)plugs clean to glazed., a vac gauge and multimeter is cheap and tells alot.
ignition problems usually backfire through the intake. exhaust/oil smells like gas, plugs may be wet.timing light and vac gauge tells alot fuel usually either falls flat,pings, retards timing, white, blistered, speckled,or extreme- melted plugs,(lean). (rich) black smoke on acceleration, backfiring through exhaust (esp. on decel) sooty plugs, cat is way hot, poor mileage and bucking. pressure gauge is cheap and tells alot. wide band o2 is not but tells all and getting cheaper all the time, don't forget a dirty, wet or restricted air filter can cause a too rich condition as well. you may only have some of these symptoms but they should fall into a category. take your time and have fun and remember there is no voodoo. if you do a (real) tune up first before you diagnose you will usualy fix the problem. Aloha |
Posted on: 2008/6/28 14:30
88 vert, gen 7, superram, blah blah blah for days |
