167 user(s) are online (128 user(s) are browsing Forums)
DaleD Cheap test items, recommendations?
Cuyahoga Falls, Ohio
1389 Posts
I gave my timing light away about 5 years ago. Nice move. I also need a fuel pressure gauge for testing. Any recommendations for brands? Price levels?
I saw some stuff on ebay. Nice and cheap. I don't need heavy duty, the only car I ever work on is my Corvette.
Posted on: 2008/3/25 19:55
donhall Re: Cheap test items, recommendations?
297 Posts
deleted
Posted on: 2008/3/25 23:14
Edited by donhall on 2008/3/26 1:53:05
Edited by donhall on 2008/3/26 1:54:02
teebee Re: Cheap test items, recommendations?
12384 Posts
I bought a fuel pressure tester kit from Harbor Freight.
Posted on: 2008/3/25 23:52
Livin_the_dream Re: Cheap test items, recommendations?
robesonia , pa
516 Posts
I buy stuff there that I will use only a couple of times. Most everything I have bought there gages wise has been accurate to within 1 or 2 PSI. There is still some stuff that is no good , but with a store close by I can lay my hands on them so to speak.
Items you may want
Multimeter
Test Light
Mechanics Stethoscope
Posted on: 2008/3/26 0:56
geogolf Re: Cheap test items, recommendations?
brookville pa.
34 Posts
ebay is your friend
Posted on: 2008/3/26 16:27
Dads90 Re: Cheap test items, recommendations?
Pearland, Tx
318 Posts
don't waste your time with a mechanics stethoscope, use a long screwdriver, autozone has a descent fuel pressure gauge. got a vacuum gauge off ebay, works good. Mighty vac from autozone is handy. Get the good timing light with tach, real handy. Spark plug wire pullers for the hard to reach plugs.
Posted on: 2008/3/27 4:29
