253 user(s) are online (215 user(s) are browsing Forums)
pappyfreebird just a haynes
1028 Posts
and dont say jack bout windsheild washer pump or tank...mines seems to leak ...and as ussual no car here to look at ...so ask in advance on how to pull it out??? . depends how where leaks but has anyone ever silliconed or plasti welded them tanks(ifn pump works course)
Posted on: 2008/4/9 16:21
NC Kid Re: just a haynes
North Carolina
1671 Posts
Why would you sillicone/plastic weld something? I mean if it was metal, then I can understand that. Maybe it's more common than I know of but have never heard of that method before. Heres a Bump to the top for you though.
Posted on: 2008/4/9 19:36
pappyfreebird Re: just a haynes
1028 Posts
hey there bvt3 whats up...well to answer you its a plastic water bottle so to speak ...so ifn just a crack (like from been frozin) then weld it shut (its called plastiweld er somethin (done on snosleds n many plasti parts or ifn a lil crack just smear it with good 3m sillicone ...save buyin a washer tank pump n all dig... ive seen some of the weldin done by cats n one dude heated steel rod in torch n melted that sucker right back to one peice ...purty cool i thought
Posted on: 2008/4/9 21:10
CentralCoaster Re: just a haynes
Pull the fender gill on that side and it comes out easily.
Posted on: 2008/4/9 22:45
TommyT-Bone Re: just a haynes
I'd silicone that water resevoir in a New York minute and take my Texas time doing it. Works real well too.
Posted on: 2008/4/9 22:57
1028 Posts
you fuggars are great thats a fact!!! thanks cc n ttb
Posted on: 2008/4/10 2:00
1028 Posts
ok rednecks thanks fer the tips...i pulled tank out taday n its the fuggan lil pump thats leakin (rather it be tank easier ta fix) but slatherd it up with some permatex n hung her back in there...now hope its sealed when fill it tamamra...next is the mirror rotating switch...n flushing the radiator
Posted on: 2008/4/16 1:17
Dads90 Re: just a haynes
Pearland, Tx
318 Posts
If it doesn't hold the pump is cheap at Rockauto.com. Did the same thing and it still leaked. Fun getting the big nut off the pump itself. I used a deep socket, extension and turned the reservoir upside down to reassemble..
Posted on: 2008/4/16 4:17
runner140 Re: just a haynes
Ft. Lauderdale, Florida
721 Posts
Good luck on the fix.
Posted on: 2008/4/16 11:32
1028 Posts
dayum that dint last long...filled it this mornin n shes leakin it out!!! well thanks to dads tip i see em at rock fer 20...next bubba question i figure since it did leak n has them lil plastic rivets (hell i need new one anyways) so i will take pump apart n have me a look see n use rivets or screws n see ifn i kin bubba it (hey just cause i like ta tinker ok)well off i go ta syphon glass cleaner
Posted on: 2008/4/16 13:22
