pianoguy | A few more project pics | ||
I added some pictures at the end, as I've made some more progress. I got the new header pipes welded to the factory cat-back, installed my Hurst shifter (and a spiffy new boot), an R-D Racing Cross-Frame, and new brakes (rotors, pads, SS lines & speed bleeders).
http://bradprestonmusic.com/Photos/Ve ... ect_Spring2008/index.html Now if the weather will cooperate, I'll be driving it tomorrow :toothy8: |
Posted on: 2008/4/19 4:02
CasetheCorvetteman | Re: A few more project pics | ||
Mate looks like youve dome some great work there, should run great ;)
Posted on: 2008/4/19 9:54
Mekanic | Re: A few more project pics | ||
How was the install on the Hurst? I've been thinking of getting one, but am a bit intimidated by the install
Posted on: 2008/4/19 10:38
crash | Re: A few more project pics | ||
THE HEADERS LOOK GREAT PLUS THE OTHER WORK YOUVE DONE
SHOULD SOUND NEAT IN THE EXHAUST DEPARTMENT |
Posted on: 2008/4/19 11:02
IM NOT COMPLETELY USELESS I CAN BE USED AS A BAD EXAMPLE |
TommyT-Bone | Re: A few more project pics | ||
I'm impressed. Looking good.
Posted on: 2008/4/19 11:56
pianoguy | Re: A few more project pics | ||
Thanks, guys!
Mekanik, the Hurst install wasn't terrible, but a few parts were a PITA. I had a helluva time getting the wedge out of the shift knob. The rubber boot that covers the top of the shifter opening had a ton of glue on it, which made removal a bear - once I got it off, I spent a good amount of time just cleaning that crap off (I used lots of WD-40 and some denatured alcohol). Some people have trouble driving the drift pin out of the shift rod linkage - mine was a piece of cake, just a few taps and it was out, and the same going back in. I used a bungee cord to hold back the lower rubber boot when disconnecting/reconnecting the shift rod - not much room to work in there. Getting the shift rod aligned to slip back onto the transmission rod was also a challenge - my wife tried to help (lifting the shifter a bit), but I wound up doing it myself. At one point while trying to align it, I accidentally knocked the transmission into another gear where the shift rod recessed into the transmission a bit, but thankfully it was easy to pull back out. At any rate, it can be done, but be prepared to be patient. And wear blue nitrile gloves - the shifter mechanism is a greasy SOB. I've gotten a lot of enjoyment out of this project - and plenty of sore muscles and cuts and scrapes. And I know my car much better now than when I started - it's quite a piece of machinery! |
Posted on: 2008/4/19 13:11
A couple other random notes:
I'm pretty happy with the exhaust - at my age, I wanted something with a little rumble, but civilized. Sounds great at WOT, and barely louder than stock at cruise. I found that when installing the Cross-Frame on my '96, I had to grind a little bit out of the frame seam next to the parking brake cable in order for the cable to tuck back in there. And I found it easier to use the Cross-Frame itself to install the nut-serts, rather than using the little backer tool they provide. I just drilled the holes, put a bolt and flat washer through each of the bolt holes in the Cross-Frame, threaded the nut-serts onto them, and lifted the frame up so the nut-serts went into the holes I had drilled. I used my floor jack to hold the Cross-Frame snugly in place while I tightened the nuts. Saves at least one step in the process. One other thing about doing all of this work myself - I've done a good bit of cleaning as I've gone along, something most repair shops wouldn't take the time to do. The engine compartment and undercarriage isn't show-car clean, but I'm sure it hasn't looked this good since mile 1. |
Posted on: 2008/4/19 13:28
Matatk | Re: A few more project pics | ||
Pics look great!
Matthew |
Posted on: 2008/4/19 13:33
Mate it all looks like a high standard of work, and you know im not easily impressed.
One thing i noticed though, the O2 location on the headers, is it at the top of the collector? |
Posted on: 2008/4/19 15:04
Thanks again, guys!
Case, yes, the O2 bungs on the collectors are at the top, angled forward a bit. |
Posted on: 2008/4/19 16:52
FLYINLOW90 | Re: A few more project pics | ||
Nice lookin work Brad.....
Should be smooth sailin' to Pa. this summer. Gary |
Posted on: 2008/4/20 1:22
I got fun..Ya want Some? :tongue: |
No worries mate yeah, thats what i thought when i was looking at them. Do you think it would be able to read the gases from all 4 cylinders each side setup like that? Not that it really matters a great deal, itll still work ok, just a great potential there for split BLMs being that its sequential injection.
Posted on: 2008/4/20 6:31
Definitely something to watch for - I think I'll pull the plugs after I've put some miles on them to see if they all look uniform.
Posted on: 2008/4/20 10:54
Will depend abit on which cylinders it takes the biggest reading from, cause they will all run abit different. The sequential injection goes even for all 8 cylinders at about 14-15% throttle, still fires them in timed order, just even for all instead of compensating for differing flows.
Posted on: 2008/4/20 11:55
The tubes aren't equal length, so I wonder if that will have any bearing. Anyway, it seems to be running great, feels stronger than before, especially in the mid-range.
Posted on: 2008/4/20 15:09
bogus | Re: A few more project pics | ||
tuned headers are such a black art... they HAVE to breathe better than the stock iron manifolds.
Looks GREAT!!!! Where did you get the trick red radiator hoses??? those are neat! |
Posted on: 2008/4/20 18:54
Thanks Andy! I got the hoses from silhoses.com - they were kinda spendy, but they're supposed to be excellent hoses, and I liked the look.
I bought an AFSB targa bar a while back on that other forum, and finally got to try it out today. Man, that thing is sweeeeeet! The car seemed even stiffer than with the fiberglass top. |
Posted on: 2008/4/20 23:50
Which bar did you get Brad??? The R-D bar??? Gary |
Posted on: 2008/4/22 11:28
runner140 | Re: A few more project pics | ||
Looks like you did a nice job. Great pic.
Posted on: 2008/4/22 11:52
96, white and a ton of miles. Somewhat stock. |
I got this one - bought it used for $300: http://www.prostreetcustoms.net/CorvettePage.html My wife likes it, as it gives her something to grab onto - LOL! |
Posted on: 2008/4/22 12:25
I was almost afraid to ask Brad.....Glad that's the one you got. IMO the R-D bar is just ugly.... Gary |
Posted on: 2008/4/22 13:23
I agree - I don't care for the square tubing on the R-D version. I'm sure it works just fine, but looks pretty fugly.
Posted on: 2008/4/22 13:45
