vetteblondie | It's all finally over with.... | ||
For those who remember, all those vette problems I'd had, no car to drive for 3 months, then the Plasma went out....
DONE FINALLY!!!!!! Have had car back for about 3 weeks now and (knock on wood) check engine light is still off - last code was the EGR. The man came to fix the plasma tv (NEVER BUY A HAIER FROM SEARS.....) and I'd bought a smaller 26 in lcd to get me by. Total list for the car..... Center muffler removed Alternator rebuilt Fuel pump Coolant temperature sensor (This little thingy does wierd things to your car I never thought possible, thought I had 3 dead cylinders or something) Ignition control module Brake booster Passive keyless in dash Passive keyless remote Opti Opti harness 02 Sensor 02 Sensor harness Balljoint on left front Rack assembly Front shocks Front rotors and brake pads EGR Valve EGR Solenoid Headlight Bushings Spoiler Gaskets Pulleys Both front rotors and pads Back tires New lugnut covers (thanks to Case) Still have some cosmetic issues, but been rolling good so far! |
Posted on: 2008/5/13 18:07
Edited by vetteblondie on 2008/5/15 16:19:44 |
The answer to any question that begins with "Am I the only one who..." is always "no". �Ugol's Law Yes, I'm a bitch... just not YOURS. |
Matatk | Re: It's all finally over with.... | ||
I remember all the problems - glad to hear everything's on the up & up!
Matthew |
Posted on: 2008/5/13 18:51
pianoguy | Re: It's all finally over with.... | ||
Should be just like new now!
Posted on: 2008/5/13 18:53
vetteblondie | Re: It's all finally over with.... | ||
Well, now that I've done at all that, at my current mileage of 224,000, is there anything else that I need to be paying any particular attention to?
Posted on: 2008/5/14 20:49
crash | Re: It's all finally over with.... | ||
DONT USE THAT BODY WAX ANYMORE
Posted on: 2008/5/14 22:32
IM NOT COMPLETELY USELESS I CAN BE USED AS A BAD EXAMPLE |
BrianCunningham | Re: It's all finally over with.... | ||
Feels good don't it?
I recently replaced a headlight motor and window regulator. |
Posted on: 2008/5/15 13:34
Funny, I'm constantly watching the dash for that darn light to come on again... Looks almost a bit odd without it being on, but I'm happy it's not
Posted on: 2008/5/15 16:20
CentralCoaster | Re: It's all finally over with.... | ||
When I see things like Opti AND Opti Harness, EGR and solenoid, etc, it tells me the mechanic is throwing parts at it, replacing the entire system insead of finding the problem.
But regardless, good to see you're back on the road. |
Posted on: 2008/5/15 17:05
Actually I saw the parts and had a mess. Last code given was egr right at the end, so I bought both parts and told him to install and be done with it. On the opti harness, part of the plug was broken and a pin thingy missing and coudn't be fixed, but ebay has the $100 part for 30. The opti itself was a wet nasty, broken mess. Not sure how all that happened. Everytime I took it in, I made sure to see what was on there before any authorization was given for anything and I supplied all parts as I can get them much cheaper than he could. Been to 2 mechanics, the first one was a dumbass, the second one who did the majority of things, got it up and running in a week. First dude had it 2 months. Parts installed were not in order as post. Thanks for all you guys' and gal's support with me and my whining though all this! |
Posted on: 2008/5/19 2:35
CasetheCorvetteman | Re: It's all finally over with.... | ||
I said the same thing myself, but in my many conversations with the beautiful blonde bomber herself they were apparently quite bad. Good to see youve got that thing running again, and you know the lug covers were no trouble at all. Im always happy to help!! Ill talk to you online again sometime soon when we both have some free time!! |
Posted on: 2008/5/19 7:01
